Technical => Engine Tech => Topic started by: bluebyyou on August 20, 2010, 07:56:56 PM
Title: Question about SO 5.0 pistons.
Post by: bluebyyou on August 20, 2010, 07:56:56 PM
Newbie here,Are the factory SO 5.0 flattop pistons forged or cast?
Post by: daminc on August 20, 2010, 08:06:36 PM
Cast.....  Welcome
Post by: hypostang on August 20, 2010, 08:08:54 PM
Welcome , what he said ^^^^^^
Post by: Sick88Tbird on August 21, 2010, 01:57:03 PM
Also, factory SO pistons are NOT flat-tops...they have a considerable dish.
Post by: bluebyyou on August 21, 2010, 04:01:03 PM
Thanks guys,i've come across a complete 88 T-bird 5.0 from a wreck with 28k miles for $250. It runs great,i just didn't know about the pistons and how much abuse they could handle. What's the compression with that dish with E7 heads? I've got a bunch of old stock mustang engine parts,STD HO pistons,cams,etc collecting dust and was just wantng to know what was the same or diffrent.Thanks for all the info again,Great site! keep it up!
Post by: Sick88Tbird on August 25, 2010, 06:52:06 PM
With that little mileage, I'd say leave the SO pistons in it for now.  With the E6's compression was around 8.7-8.8:1 but the E7's have a little smaller chamber.  Figure around 8.9-9.0:1 with E7's....unless you send them to the machine shop and take .030" off.  Then you should be close to 9.3-9.5:1 depending on head gasket.
Post by: Beau on August 26, 2010, 02:26:57 AM
If you're going to run anything more than an HO cam, the SO pistons will NOT work...not sure about some of the alphabet cams, but the HO cam will work with SO pistons.
Also, as an option, you can have them fly-cut, but for the trouble and cost, HO pistons would be better, plus you already have 'em...
Post by: V8Demon on August 26, 2010, 09:53:55 AM
Quote from: Sick88Tbird;332857
The dish is 2.5 cc.
Quote from: ThunderbirdSport302;333530
Depending on what heads are being utilized; this may not be true.
You'll never know 100% for sure unless you measure PTV clearance.
Example: Trick Flows TW heads, flat tops, no valve reliefs, .565" lift and roughly 225 degrees duration @ .050" lift....  LOTS of clearance.....
Post by: V8Demon on August 26, 2010, 09:59:07 AM
Quote from: V8Demon;333548
The dish is 2.5 cc.
Post by: Slinky on August 28, 2010, 10:58:45 AM
You should go to the CoolCats.net and read about the H.O. conversion it will probably answer a lot of your questions.
Post by: Beau on August 28, 2010, 05:28:47 PM
The dish is 2.5 cc.
Right, I forgot to put that in my other post...better to err on the side of caution any which way. :D
Post by: Dougy_Fresh on September 02, 2010, 09:49:30 AM
i'm running a B303 cam with stock flattops and stock e6 heads so thats another one that clears...
Post by: Sick88Tbird on September 05, 2010, 01:40:23 PM
The factory E6 heads have their valves recessed much further into the head than E7's or other factory Ford heads.
Post by: t.birdsc on September 16, 2010, 11:24:21 PM
A local machinist told me he prefers the e6 turbo swirl design chambers to the e7's. He basically said the e7's are junk and everyone gets too caught up with flow numbers of cylinder heads in general. If you know what to do, the e6's could be made to out perform the e7's in his opinion with the better combustion chamber design.
Post by: Beau on September 17, 2010, 01:32:59 AM
Right, because E6's flow better and make more power than E7's is why Ford switched in 1987 on trucks, Stangs, and Mark VII's. :rolleyes:
Hey, if E6's are so darn good, I've got a set (or 3) I'll sell for an all time low price of just 79.99 each! :hick:
Somewhere online is a flow chart of E5, E6, E7 and later 5.0 heads....E6 actually do flow worse than any other 5.0 head made since '69 or so. Proven.
Of course, I see in your sig you have a paxton on yours, with a little air pressure i suspect there's not a hell of a lot of difference.
Take a stock '87-'93 HO, swap stock E6 heads on, dyno it, and get back to me. ;)
torque will be down (a lot), horsepower will be sucked out of the engine, and it won't make power over 3500-4500 max.
So I will kindly disagree with your machinist, in regards to stock E6 heads being superior to stock E7's.
Post by: vinnietbird on September 17, 2010, 06:44:10 AM
I have read that the E-7 heads are where thew extra 20 HP came from when the HP rating went from 200 to 220 back in the day.I could feel the difference between the two when I swapped the E-6's for the E-7 heads ....granted,my E-7 heads were ported and had a nice valve job and better springs.
Post by: hypostang on September 17, 2010, 07:21:23 AM
Quote from: ThunderbirdSport302;335858
Ok Normally I dont  do this BUT there are some factual errors here.;)
 1. trucks never used E6 style heads
2. Mark Vii's didnt even use HO engines till very  LATE 87
3.E5s and E7s are  near identical
4. 86 5.0 was only rated at 15lbft less torque than 87 up (not "a lot") less
5. all 5.0 HO engines are rated max hp @4000 rpm factory.
6. Flow charts  really dont mean squat ..dyno results do (this is just my opinion )
7.t.birdsc was relaying a  certain machinists "opinion" on  a starting point  for head  work and  that said machinist feels he can achieve  better  results with  the high swirl chambers on the E6s
 Now with all those points being made
 here is my "opinion "
E6 and E7 heads are not much more than boat anchors compared to GT40s and the aftermarket selections out there , personally I  could not justify swapping E6 heads for E7 heads because the gains would be so minimal in relation to the effort involved in labor .
 If I am swapping heads it is going to be for WAY more than 15 lbsft and 20 HP :D
Post by: 1BDBIRD on September 17, 2010, 01:17:41 PM
I got two sets of e7te heads laying around,roller block,cranks,roller cams,spyders,rollers,dog bones!!! pretty much worth nothing to me!!!!
So pistons ho pistons couple aods. taking up space!!!!!!
Post by: Haystack on September 17, 2010, 06:43:56 PM
I really would not worry too much about either head. If you shooting for power, and RPM, why shoot yourself in the foot with stock heads? I'll be new springs and hardware could make a ton more power if properly matched.
Post by: turbo_88_XR7 on September 18, 2010, 01:21:23 AM
well i can tell you this much from experience.. a .540 lift cam does NOT like SO pistons LOL
