hey guys i dont know if this is were it sould be.. i just put a clutch in my 88 tc 5spd. got it back on the road and i currently have 147 break in miles on it. i just tackled an electrical problem with my no tack and speedo and some other stuff, turned out to be fuse 18 witch was a 10 amp witch i replaced with a 15 but i fixed that befor i did my clutch job...and it worked and it was fine till i was doing something in the yard and i hit my switch for my head lights...car wasn't running just used the battery.. the first thing i noticed was there was a buzzing and i poped the hood and theirs a black box on the passengers side of the car just steady buzzing and vibrating slightly. how do i fix that..also my voltage regulator is bad i belive because if i start the car with just the engine running no radio lights ect the tack needle is fine. if i flip the lights switch the needle drops to 500 rpm or 0 rpm and the speedo side of the cluster inset lit up the ford green it should..its half dead lol. and if i hit the turn signal the speedo needle jumps to 15 mph each time it flashes and my high beam light goes on and its just a mess....my slave cylinder for the clutch went out today also so i have to fix that any tips or anything that might be able to fix this problem?? help!!
oh sorry guys i found it my computer was messing up ill post it in the electrical section sorry
