ok i have instaled the petals i have the tranny from a turbo coup what else do i need .the engin is a 1969 351w .i need a pilot bushing from a ford probe.what year and stuff i need a v8 spacer plate a cable and quadrent i proly know this stuff but im tired i dnt wana think.....lol yes im to lazy to think
T-5 from a tc might be a bad idea on a 351w unless your building it for some old folks to get back and forth from the Senior center ( no offense Tom lol)
Seriously I think the 4cyl t-5's have trouble on a 302HO with just some bolt-ons
the pilot bearing is a A203 it is a common alt bearing , there are several, just make sure the one you get is sealed on both sides.
what trans number are you running, ther should be a tag with the numbers on it...
check this chart...
http://www.therangerstation.com/tech_library/T5ID.htm
depending on witch T5 you have from what year TC the torque rateings for them range from 235-240 ft/lbs
I know the T-5 conversion for a V-8 T-5 is the same as it is with a Mustang. This is how I converted my '83 over to a T-5 back in '94. The only think I did was find a TC steering column to get rid of the column shift selector.
Darren
