Technical => Body/Appearance/Interior => Topic started by: Crash225 on August 05, 2010, 07:23:38 PM
Title: Header Panel question
Post by: Crash225 on August 05, 2010, 07:23:38 PM
I'm finally putting the header panel back on my cat and I have a question concerning these self-tapping bolts and nuts:
(http://i736.photobucket.com/albums/xx9/vbprog225/Headerpanelanchorbolt.jpg)
When I screw these into the header panel they seem kinda loose and not too secure. As a matter of fact, most of the bolts backed out of the header because the nut wouldn't come off! I thought about using an epoxy to better secure the bolts in the header panel. Has anyone used a better method? If so what did you do?
Post by: vinnietbird on August 06, 2010, 05:30:34 PM
I used some body panel adhesive I had from another project. JB Weld would probably work.
Post by: Crash225 on August 07, 2010, 05:00:03 PM
Thanks Vinnie, I'm going to try and score some of that adhesive at the Advance Auto tonight. Hopefully I'll get this done before the end of summer.
Post by: vinnietbird on August 07, 2010, 10:34:45 PM
Body panel adhesive is kind of high priced. I'd go with JB Weld and let it dry for 24 hours.Don't get the quick stuff.Get the original JB Weld.
Post by: Beau on August 07, 2010, 10:39:54 PM
Just make sure that whatever you get adheres to fiberglass..;)
