Can I swap the digital clock from my 88 Sport and put in a anolog clock from another older tbird? Is it a plug and play or is there rewiring?
not exactly sure, I have both clocks but cant remember if the connector is the same or not.
Yes, you can swap between buttstuffog and digital, any year, 1983-88. Only the Tripminder had a different wiring setup.
I've got both clocks for an 85. Same plug for power, but I have additional bulb with wire for the backlighting in the back on the buttstuffog clock. Sure it can be piggy-backed.
Cool guys. Thanks for the info. I saw one in a 85 Tbird and I though that it would look better in my 88 then the digital one. Kinda give it a different look. Looks better with the dash gauges.
