Has anyone setup two oil pressure gauges. I'm looking to add a real oil pressure gauge and keep the stock one. I imagine I need some sort of T setup on the log.
I was going to add the oil pressure gauge and a real temp gauge above the radio where the stock EQ would go.
I used a "T"fitting in my mark VII , most any parts store , or even Home Depot/ Lowes should have what you need
technically it was a "Y" one male two felmale
I'm doing the same. I t'd it. I have three 1.5" gauges in that hole.
Bob,
It's pretty simple. Just add a 'T' prior to the stock sender and run the tube to the new guage. 'T's are typically available at a full service hardware store.
If you have full accessories, the toughest part is getting to the port in the block to add the 'T'. A 45 degree elbow may be needed for the stock sender to clear a P/S pump.
Mark
Cool sounds good, if anyone has the time snap a couple pics for me of your setups, I'm very visual when it comes to this stuff... LOL
Whats a good solution to add another temp gauge in addition to the stock temp gauge?
It's an old pic but it does show 2 of 3 gauges. It's been redone since but I don't have pics. I need to do that soon.
I had to edit , shiznit I got 3 pedals now,and not a new cup holder.
I like the interior color ;)
I meant a pic of the y setup at the block if you get a chance
I love red interiors, I noticed something interesting,key in the ignition , beer on the console ...That's a DUI here in TN :evilgrin:
I put a T in mine years ago
(http://i233.photobucket.com/albums/ee79/daminc/cougar%20before/IMG_2834.jpg)
I actually used a pipe and a t. on mine. I'll try to find a pic if I have one
