Technical => Misc Tech => Topic started by: Scott D on July 26, 2010, 07:05:22 PM
Title: Clutch or Compressor?
Post by: Scott D on July 26, 2010, 07:05:22 PM
So, in this thread (http://www.foxtbirdcougarforums.com/showthread.php?t=28887) I speak of the a/c compressor not working right.
Here's what's going down ...
with the A/C off, the pulley works fine, no issues at all. When the A/C is turned on, it'll start smoking, although the pulley still rotates with no apparent issues.
Should I look into replacing the compressor or the clutch assembly first?
Post by: jandmmustangs on July 26, 2010, 07:11:32 PM
Compressors are a dime a dozen.  Throw a known good one on and forget about it.
Post by: Scott D on July 26, 2010, 07:30:09 PM
Quote from: jandmmustangs;329592
I'm seeing 285$ for a new Motorcraft compressor from O'reilly's w/o the clutch and am waiting for the store to get a price on a Motorcraft rebuilt unit. I'm seeing about 90$ for the Motorcraft clutch assembly.
Post by: jandmmustangs on July 26, 2010, 07:58:48 PM
I know they're expensive new.  Im just used to having a few good ones lying around.
Post by: Thunder Chicken on July 26, 2010, 08:12:39 PM
With the engine off grab the center of the pulley and see if it turns. If it doesn't your compressor's seized. If it does either your clutch is slipping from wear or the magnetic coil isn't strong enough to engauge it all the way. There's also the possibility that your E-fan isn't turning, causing excessive pressures which might cause the clutch to slip.
Post by: Scott D on July 26, 2010, 08:19:48 PM
Quote from: Thunder Chicken;329600
E-fan?
edit - I like how you highlighted with the engine off ;)
Post by: Thunder Chicken on July 27, 2010, 05:11:59 AM
Electric fan. Assuming your MN12 has one. If not, it may be the fan clutch.
Post by: Scott D on July 27, 2010, 05:32:19 AM
Quote from: Thunder Chicken;329635
That's what I was thinking you were referring to. The fan's not driven by the accessory belt, so I'm sure that can be safely excluded from any list of issues.
Post by: Thunder Chicken on July 27, 2010, 10:23:55 AM
If the E-fan isn't working your A/C pressures can get extremely high and stall the compressor, causing the clutch to slip. This problem would show itself if you had gauges attached (your high side readings would be very high). Your E-fan should come on any time the A/C is on.
Post by: Scott D on July 27, 2010, 05:12:27 PM
Quote from: Thunder Chicken;329650
See, I'm slow :)
I've got the car at the shop, right now, although it'll be another day or two before they get to it.
As best as I remember, the fan's working fine. When my wife rolled in, and I looked where the smoke was coming from, I recall the fan was working. When I drove it home, it didn't get above normal temp.
If the shop tells me the fan's bad, I won't be surprised now. Thank you, sir!
Post by: TurboCoupe50 on July 27, 2010, 10:32:41 PM
IF the clutch starts smoking almost immediately as soon as the A/C is turned on you mostly likely have a compressor problem... IF it were the fan, the engine would no doubt be overheating...
On a TC I had that the fans were not operating, the A/C started cooling normally but evaporator temps soon rose till the point there was no cooling, clutch never slipped... If the car was moving, the A/C marginally cooled...
Post by: Scott D on July 28, 2010, 07:59:23 PM
Quote from: TurboCoupe50;329749
Yup, that's what was going on. I don't particularly like that it's going to cost as much as it is going to, but I want to keep the 'underbird in showroom condition. So, all Motorcraft parts are going in, even though it'll raise the bill by a little bit.
Right now I'll be getting the A/C Compressor & clutch assembly changed, and the system charged. I figure I'll go ahead and have the shop put in a new water pump so I don't have to worry about that later on. And, considering they've got to flush the radiator when they do the water pump, I'm going to go ahead and have the lower radiator hose replaced at the same time. So, this'll end up costing me right around 1600$.
I'm glad I've got some extra guns around to help fund Project 'underbird's recovery.
Post by: Masejoer on July 28, 2010, 08:22:10 PM
That's very spendy. I have no idea what's involved to swap out the water pump on the 3.8 but I think it's possible on the 5.0 in a morning (<4 hours) and the compressor/clutch assembly is minutes (again, no idea where it's at exactly on the 3.8's). I would think that such a job, with new Motorcraft parts, would come in around $500 after markup for a Motorcraft compressor, clutch (I priced them separately at ~$350 total for the pair but not 100% certain if the $210 compressor comes with a clutch), water pump, and lower radiator hose and then 6 hours at $85/hour, coming out to about $1000 for both at an expensive shop with all Ford parts. Add coolant and A/C for another $50 in materials. As long as they don't break any bolts or studs off, I don't see why it couldn't all actually be completed in under 4 hours by a shop that knows what they're doing. Am I too far off guys? The labor sounds like what we see with shops randomly quoting numbers based off of the more compact front/all wheel drive engine bays.
Does that price include anything but the water pump and compressor? I usually see $1600 quotes include water pump and timing belts/chains since everything's already pulled apart and they're accessible.
Post by: Masejoer on July 28, 2010, 08:34:32 PM
The 3.8's compressor is on the upper passenger side, right? Easy to change. I should add an additional $100 or so to my above numbers as they should also flush the system out and check/replace all sealing points (orings mainly). Still nothing that should take more than 15 minutes to pop the connectors apart, pull old o-rings out, oil up new ones, and slide it back together.
I just don't want to see you be taken for more money than the shop deserves. I have no idea what estimates their books, or computers, tell them though as they're usually way over in time of time required to replace a part (again, except when some old rusted stud snaps off that they have no control over other than that they shouldn't use an impact driver on such parts).
Post by: Scott D on July 28, 2010, 08:40:15 PM
No, seek, that quote is just for what I listed. They base the estimate on what the computer tells them it'll be. But, they have a good history with me and only charging what labor is actually done (as opposed to some shops I know of that bill what the computer tells them). I'm one of the odd folks that actually prefer a high estimate, so I can budget that and get lucky enough to spend less, rather than be surprised by additional costs.
One example is when my wife had the accessory belt changed on her car. The computer showed something like 98$ for labor and 30$ (or something like that) for the belt. Well, the mechanic told the girl at the front desk, "it only took ten minutes for me to change that, don't charge her 98$." So, it was corrected to 10$ labor.
They've saved me money with other repairs on other vehicles I've had, too.
Post by: hypostang on July 28, 2010, 08:54:54 PM
WOW ! I'm glad I can do most repairs myself , $1600 is 4 times the purchase price of my car :hick:
Post by: Masejoer on July 28, 2010, 09:01:19 PM
Let me know how it comes out then - I'm curious as they should be able to do it in much less time. While it's odd for a place to estimate like that, perhaps they are planning for broken water pump bolts/studs and the work involved in extracting them (or repairs for more forceful removal of said broken bolts/studs)?
Not sure where that belt estimate could have come from - it's one of the easiest things to change on all cars. Some cars' batteries are more difficult to replace ;)
Post by: Scott D on July 28, 2010, 09:30:19 PM
Quote from: hypostang
If I had the time to, I would do it myself, too :burnout: ...but after 14 hour days, sometimes, I look at paying somebody to do it as a convenience. And, the car actually gets fixed. My Silverado's windshield wiper controls effed up about a year, or so, ago. Rather than spend 100$ for the part and the time (or labor) to put it in, it's just as easy to put the fuse in/out when it rains
Quote from: Seek
They usually offer "worst case scenario," for me, but I'll keep the cost updated when I get the work done.
Post by: TurboCoupe50 on July 28, 2010, 10:44:14 PM
The system will have to be flushed and then evacuated, just like a hooker they'll charge for the time the pump is sucking...
Post by: Masejoer on July 28, 2010, 11:30:45 PM
Quote from: TurboCoupe50;329850
Wouldn't be surprised. What's the standard protocol at places on how long they have to hold vacuum? I would assume most places would use something that can go down to some really low micron rating/close to perfect vacuum but if you truly had a decent pump, you'd only need to hold it for a couple minutes.
I would assume they'd also stop the pump and watch for leaks at the same time...and charge you for the time that they aren't doing anything but waiting. If this shop is as good as he says they are though, they'll ignore such time (I've gotten to work with some great shops around here lately - getting a lot of time and some materials without charge). Friendly shops wouldn't add these costs into the estimate in the first place. Maybe it's because I know how much effort some tasks would actually take though and they know it :p
Post by: Scott D on July 31, 2010, 01:51:26 PM
Here's the exact quote ...
Compressor/Clutch Assembly - $484.73
Drier - $249.14
Orfice - $3.37
Flush - $89.95
Oil - $12.00
R134 2.12 - $40.18
For a total of $879.37 in parts (all Motorcraft parts)
6% tax - $52.77
Machine - $59.95
Labor - $249.50
For a grand total of $1286.59
I figure since I'm dropping that much coin, I'll get them to do the water pump and lower radiator hose. Here's the quote for that ...
Water Pump - $106.38
Antifreeze - $48.00
Total in Parts - $154.38
6% Tax - $9.27
Labor - $170.00
Total - $333.65
Grand Total - $1620.24
Post by: TurboCoupe50 on July 31, 2010, 04:44:53 PM
WOW, I'm more valuable than I thought, sure glad I do all my own work...
Other than the compressor being rather high the A/C job seems reasonable, but $170 to change a water pump on a 4.6 is insane... On models with a electric fan, it's a 20 minute job tops...
OOPs forgot you have a 3.8, I dunno what those involve to replace, never touched one(I refuse to even gaze inside a open hood of any Ford with with the 3.8)...
Post by: Masejoer on July 31, 2010, 05:46:18 PM
Not sure about the cost of the drier as it seems a bit steep but I can't find the Motorcraft pricing. I know my '88's accumulator is like $80 but it was also used on the fox Mustangs of so many years. Compressor may be 30% high also but other than that, the costs seem reasonable - the typical going rate for certain tasks (individually - I would expect a little less since it's all happening at once). The listed A/C work should honestly only take them about an hour tops though (with exception of them charging for waiting for the vacuum pump/leak check).
I think similar work on the A/C on the '88's with r12 comes out to about $800 with labor at a shop with Motorcraft parts. I can only assume that the '97 parts are more rare as again, the fox Mustangs are very popular and have helped keep prices down on the fox tbirds.
The best thing most people can do who wish they could work on their own cars but afraid of the potential issues is to find a buddy to work with. They may not know more than you but you can share an agonizing experience with someone else :p
Post by: Scott D on July 31, 2010, 09:18:15 PM
Quote from: Seek;330122
The A/C compressor was used on 57 different year/model Fords. From the '93 Aerostar to the 2003 F-250, to the '94-2004 Mustangs.
Post by: vinnietbird on July 31, 2010, 09:46:06 PM
So far I have bought the following for the Sport....
-Compressor (used...but less than 1000 miles on it)
-bracket
-harness
-all three lines (new)
-smog delete
-belt (new)
-condenser (new)
-evaporator (new,but not using it)
-Steering pump for new a/c bracket (new,and FREE).
I have a total of $185.00 invested. I still have to have the guy convert it to the new stuff and install the seals,but I'll install all of the components themself.That'll save a lot I'm sure.Not hard,just time consuming.
Post by: Scott D on August 01, 2010, 07:09:45 PM
Quote from: vinnietbird;330160
See, I don't have the time. So, by paying somebody to do it is a convenience for me, in a way.
It's not going to stay that way, though. Andi was talking about getting a carport built so I don't have to worry about it raining and a project not being done.
Post by: Scott D on August 25, 2010, 07:25:06 PM
I know it's dangerous, but I was thinking ...I told you I knew it was dangerous ...
I'm gonna do the A/C work myself :headbang:
Post by: Scott D on August 28, 2010, 12:51:29 PM
Well . The head guy @ work's shop didn';t have the tools to take the lines apart. He has a buddy that owes him a favor, so looks like I'll bring the parts I bought to him to get done, I reckon.
