Can somebody with an '87-'88 Sport or a Turbo Coupe with original dual exhaust post or send me some detailed photos that show exactly how the brake line routes from the underbody to the axle and also how the fuels lines route. I am adding dual exhaust to a 1985 and I want to attempt to mimic the factory routing as closely as possible. Thanks!
the brake lines and fuel lines run down the pass side
the fuel lines run up into the wheel well on the pass side then cross over the fire wall to the driver side
the brake lines run from the combo valve and across the K member and follow the fuel lines to the front of the rear wheel well then cross over to the inside of the upper control arm on the driver side, then the flex line to the rear for the split to the rear calipers.
sorry but I do not have any pics showing that.
