86 Raven upper rear sail panels-$25
86 Lower quarter panels with grey leather inserts-$25
88 consols center control panel for dual power seats, windows and mirror- near mint-$60. one of the best I have seen!
86 manual flywheel-$25.
86 tran crossmember-$20
86-88 engine mounts-$30 pr
86 alloy sill plates, small dings no corroded- $20 pr.
black plastic doos sill trim panels- $15 pr.
86 door and rear side window trim ribbed-$45.
86 trunk lid carpet-$35.
86 third brake light-$20
86 steering column cover with tilt ring-$25.
Parts are located in harford co, maryland and local pick up welcome
by chance do you have the bracket on the trans for the shift lever. or do you know anybody that has one.
I think I do have one. I'll check tonight and let you know
I do have one with a shifter assembly, I could seperate if the deals right. Pm an offer
Updated list!
