Technical => Suspension/Steering => Topic started by: 1986Élan on June 21, 2010, 10:15:34 AM
Title: turbocoupe front swaybar
Post by: 1986Élan on June 21, 2010, 10:15:34 AM
was its size 1 1/4 or 1 5/16
i think it was 1 5/16 but just wanted to make sure
thanx all
Post by: 1986Élan on June 21, 2010, 07:22:43 PM
anyone???    input is appreciate
Post by: hypostang on June 21, 2010, 08:37:33 PM
1 and 5/16 is correct
Post by: hcor on June 21, 2010, 08:41:32 PM
I have 3 -86 turbo coupes sitting here with 1&1/4" bars on them stock. It's only a 1/16 differance.  What size does a standard T bird have on them?
Post by: hypostang on June 21, 2010, 09:02:37 PM
Mine is from an 88 , so I can only speak for mine :D
 I have no idea on the earlier cars but my stock bar was 1  and1/8 , my car is a V8 lx
Post by: 1986Élan on June 21, 2010, 09:49:07 PM
hcor you have pm
Post by: BogusSVO on June 23, 2010, 11:27:40 AM
the tc have the 1 1/4 sway bar on front
the frame bushing  (engery suspention ) part number is 4.5108
Post by: hypostang on June 23, 2010, 01:03:54 PM
What method are y'all using to measure the bars ?
All my part reference catalogs dont even show 1 1/4 bars listed
1 1/8 and 1 5/16 are the only bars over 1 inch
Post by: 1986Élan on June 23, 2010, 01:31:31 PM
http://www.energysuspensionparts.com/proddetail.asp?prod=MustangFrontSBB
Post by: hypostang on June 23, 2010, 04:35:25 PM
Quote from: 1986Élan;326278
I have listings for a  1 1/4  bar for stangs but not birds :confused:
When I put my bars on my car I bought these  bushings
 moog #k80097
I used the wrench measure method
Post by: BogusSVO on June 24, 2010, 11:15:25 AM
I used a set of veiner calipers  and measured between  1.255 and 1.290
I have about 4 85-88 TC front sway bars laying around
with the enery suspention bushings and endlinks, it stiffen up the 85 alot and handles a ton better.
Post by: hypostang on June 24, 2010, 02:59:24 PM
I see,  from what I understand 5/16 is like .30/.31ish
So I guess there is a real little difference .
 Maybe I will try the energy suspension bushings
Post by: BogusSVO on June 24, 2010, 05:35:40 PM
5/16 is .312
unes your dealing with valve stems, then they range from .311 to .315
Post by: hypostang on June 24, 2010, 08:29:41 PM
Quote from: BogusSVO;326382
5/16 is .312
I was guessing after trying to do math in my head  :hick:
 I went down to my garage again today and a 1 1/4 in wrench does not fit on my bar , I'm calling it  production variances :D
 poor quality pics but I think it shows what I mean
Post by: hcor on June 24, 2010, 09:38:11 PM
I remeasured with a micrometer and came up with 1&5/16
Post by: BogusSVO on June 25, 2010, 05:32:18 PM
the 1 5/16 bushings will be a tad loose tho  get the I 1/4 ones  they have a bit of a crush
I tried the 1 5/16 and got a bit of a clunk,  installed the 1 1/4 and no more clunk
dont forget the matching end link kit !!
