Where can I find a new headlight switch for my cougar? it's the kind with the flip switch not the push pull type and has the dimmer wheel built into it.? I checked advanced auto parts, auto zone and pep boys. no luck they all have the push pull type listed.
thanks
GB
I have never been able to find a new one , I grab them from the salvage yards whenever I find them ( Mark VII has the same switch)
I'm going to be grabbing all the switches I can.Our parts are drying up fast and getting harder and harder to find.
thanks, I think i work out a custom dash for my cat then. I used to build them back in the day before the recession hit.
I bought mine from Rock Auto when it needed replaced. Not sure if they have any more though.. for some reason I was thinking that was the last one... lol..
I have several good ones if you need one.
Hypostang. I looked up mark VII at auto zone. they have them special order only though . they are $35.00 each and the plug backs are the same only difference is they don't have the heat sink on the side like the cougars did.
My mark VII LSC had the heat sink , I dont know if the base/Bill Blass model has it or not .
I bought one for my 88 a few years ago. The one I bought was an AC Delco part.
RockAuto does still show the listing for a mark VII
The LSCs were the only ones. The heatsink let the switch run the foglights without burning up.
Mine have heat sinks. Not sure if they're the same as the Mk 7s.
That makes sense , however my bird has the heat sink and its not a TC .
I guess its another "why did Ford do that " kinda thing
