Technical => Body/Appearance/Interior => Topic started by: t3skidoo on May 31, 2010, 10:25:43 PM
Title: arm pad replacements -
Post by: t3skidoo on May 31, 2010, 10:25:43 PM
In the never-ending war on weight, and since the back seat is mostly for looks, and the arm pads vestigial ...
A sheet of acrylic from the local home destruction store, cut to fit and topped with some plastidip rubber.  Some silicon to keep them in place once they're dry.  If they don't work out, they will be relatively easy to replace with the pads.
Post by: t3skidoo on June 01, 2010, 12:16:55 AM
test fit
Post by: fluke on June 01, 2010, 12:27:42 AM
Those look clean. :)
Post by: jrad235 on June 01, 2010, 12:49:30 AM
So...3Lbs saved maybe?  Those do look pretty decent though.
Post by: t3skidoo on June 01, 2010, 03:14:53 AM
Quote from: jrad235;323905
Yeah, that's about right.  It's cheap weight and easy to do.  A MM K is about $30/lb saved, this is about $2/lb saved.
