Looking for another 5.0L upper plenum plate. Let me know which one you have. Pics would be nice.
Ive got several, Ill try to get some pics. You can sand the paint off whatever else you want on the painted black one.
Ttt
if you have another extra i could use one. pm price with shipping. thanks
Ill grab some more at the yard next time. If Tyler doesnt want one Ill let you know.
thanks, will both fit or each diffrent? mines the black one.
I've got a few,but they are all in the process of being polished.They'll go for about $35-$40 each depending on which one a person wants.
You got any with just 2 holes?
For the Explorer upper? Here's the easy trick I did. I just cut the heads off two screws and glued them in the extra holes on the plate. You can't tell when the plate is installed that only two screws are holding it on ;)
what's wrong with just putting a plate that has 2 holes back on.
I made my own from aluminum sheet.polished,smooth,and only two holes.Took about ten minutes to cut and drill the holes,then about an hour to smooth and polish it.FREE as well.
I was thinking about re-machining a plate anyway, so If I had an explorer 2 hole plate, it's not really going to matter. Anyone got a 2 hole'r they want to give a new home
It limits your "style" selection;) If you're making your own plate you can do what ever you want though:D
I'll sell this one for $13 shipped to the lower 48 of the USA
send that bad boy my way! save me from painting it red! thanks, dwight
Just throwing this out there:
http://www.bcbroncos.com/store/product_info.php?products_id=1386
(http://www.bcbroncos.com/COVER%20PLATE%20BLANK%20CUT%20WEB.jpg)
A little pricey, but nice and clean....
Do you need more?
All my explorer plates have 4 holes, just have a bit of paint or sealant in the unused ones. Not sure there is such a thing as a two hole explorer plate.
My Explorer plate has two holes. All of my Explorer plates have only had two holes. There are two fake holes (little indentions),but only two actual holes for the fasteners.
