Marketplace => T-Bird/Cougar Parts & Cars FOR SALE => Topic started by: Watchdevil on May 10, 2010, 07:18:47 PM
Title: Delete
Post by: Watchdevil on May 10, 2010, 07:18:47 PM
Delete
Title: Header Panels
Post by: Watchdevil on May 10, 2010, 07:51:50 PM
Delete
Title: Batch 2 Assorted parts as listed
Post by: Watchdevil on May 10, 2010, 08:09:51 PM
Batch 2
A: buttstuffog clock in perfect working condition. Hands painted Thunderbird Blue but easy to change. - $20
C: Illuminated door lock cylinders - $5
D: Power mirror joystick - 83-84 models - $5
E: 83-84 Wiper switch with intermittent control. Fits many other Ford models of various years. - $5
F: 84 Tbird A-frame steering wheel horn cap - Charcoal color- $5
G. SOLD
Buyer pays shipping.
Title: Delete
Post by: Ether947 on May 10, 2010, 08:35:23 PM
I want E!!!!!!!!!!!!!!!!!!!!!!! From Batch 1. Dude, if those are still available you just made my day.
Title: Batch 3 Assorted Parts
Post by: Watchdevil on May 10, 2010, 08:42:06 PM
Batch 3:
A. 85-86 Tbird grille with no emblem. Aged condition with chrome pitting. - $5
B. 1985-86 Mustang standard vinyl steering wheel. Fits all Fox Tbirds and Cougars without cruise. If you have cruise it does in fact have three contact rings and you can indeed plug in the cruise switches and hide them inside the wheel behind the horn pad which snaps on/off quickly. When you need to use the switches, you can attach velcro to them and place them wherever you want on the wheel so you can use them while cruising. Horn pad repaired and now works but has no screw studs to secure it from behind the wheel. However they are not needed as it satisfactorily snaps into place on the wheel and stays there just fine. Ford oval emblem missing in picture but is now installed on the horn pad. - $20
E. Lower Steering Column covers - Two available - Dark Charcoal (almost black) - fits most Fox platform cars. - $5
F. Upper Steering column cover - Dark Charcoal (almost black) - Fits most Fox platform cars with column mounted automatic shifter. - $5
G. Tilt wheel collar - Dark Charcoal (almost black) - Fits most Fox platform cars with tilt wheel. - $3
H. Power Antenna Switch and trim plate. Fits all 85-88 Tbirds and Cougars. - $5
Title: Delete
Post by: Watchdevil on May 10, 2010, 08:43:12 PM
Quote from: Ether947;321409
They are yours if you want them man... PM me!
Title: Batch 4
Post by: Watchdevil on May 10, 2010, 08:55:10 PM
1983-84 Tbird and Cougar Dash parts.
A: Dash cap - ABS plastic - Never used - $20
B. LH or RH Dash vent. - $5
C. Right Dash Panel Trim - Polished to a gloss finish. Can repaint to match original satin finish. - $10
D. 1983-84 Oxford Gray driver knee pad. 8 out of 10 condition. - $25
E. 1983-84 Oxford Gray padded glove box. 8 out of 10 condition. - $25
Title: Delete
Post by: 85cougar on May 10, 2010, 09:11:00 PM
pm sent
Title: Crystal Clear Headlamps
Post by: Watchdevil on May 10, 2010, 09:15:09 PM
Crystal Clear Headlamps. 4" X 6" H4651/H4656/H4666 Sealed Beam Conversions. Installation requires enlarging openings in back of metal headlamp buckets for proper fit.
Includes city lamps. City lamp bulb is positioned on left side of each lamp. One city lamp bulb per lamp. Uses 194 bulbs. Includes headlamp bulbs - Use your own choice of colored bulb or purchase colored gel caps from a local auto parts store. You can also install LED's which can be purchased for very reasonable prices on eBay.
Set of 4 - $15
Title: Batch 6
Post by: Watchdevil on May 10, 2010, 09:51:19 PM
Cluster requires repair to Shift Indicator cable to be functional.
Odometer can easily be reset to your mileage. If need be I can do this for you before shipping.
Standard buttstuffog Cluster - Needles painted Tbird blue. Fuel gauge recently replaced and working. No mounting tabs for cluster as they were cut off for modified fit into a non-stock dash. Hardware store L-brackets will secure it to dash, or just use parts inside cluster to repair yours. - $15
There is also a buttstuffog dash clock with matching Tbird blue hands available in previous batch of parts for sale.
Title: Delete
Post by: hypostang on May 10, 2010, 09:58:32 PM
Is the digital 85-88 speedo the same as the all digital cluster speedo?
 And what is the mileage if you know?
Title: Delete
Post by: Watchdevil on May 10, 2010, 10:06:28 PM
1983-84 Tbird taillamps. Will fit 85-86 with enlargement of center opening on each side of the rear body panel. All other holes align.
RH taillamp good condition. LH taillamp has hairline crack in the rear side market area which is inside the lens and not through to the outside.
RH Taillamp $15
LH Taillamp $10
Dash pad for 1980-82 Tbird and Cougar and 1983-86 Midsize LTD and Marquis.  Dash pad has no cracks and seems reasonably pliable. Recommend spray or dying color to match. Just add trim strip from your old pad. - $15
Title: Delete
Post by: Watchdevil on May 10, 2010, 10:10:26 PM
Quote from: hypostang;321428
This is the standard cluster for 85-88 models. I believe the speedo unit itself is identical to the full digital clusters. I have no idea what mileage is on it.
Title: Delete
Post by: hypostang on May 10, 2010, 10:18:37 PM
Quote from: Watchdevil;321431
Thanks
I had a spare that I was going to do the +85 mod and when I tested it it was junk .
I'll get back to you after I go to pullapart this week
Title: Delete
Post by: 88turbo on May 10, 2010, 10:24:01 PM
B. Crystal clear lamps with city lamps.
how much is shipping to 67005?
Title: 85-88 Dash parts
Post by: Watchdevil on May 10, 2010, 10:47:41 PM
A: Left speaker grille. Regatta Blue. Clip missing or tab broke off. Some intact. Secure with velcro. $3
B: Right speaker grille. Regatta Blue. Clip missing or tab broke off. Some intact. Secure with velcro. $3
C: LH Side window defroster vent. Regatta Blue. $2
D: RH Side window defroster vent. Regatta Blue. $2
E: LH Dash vent only. Light Charcoal. $3
F: RH Dash vent complete. Regatta Blue. $3
H: Headlamp switch trim panel. $3
I: Dash top center trim. Regatta Blue. $2
J: Auto antenna switch trim. $2 (Antenna switch for sale in earlier post)
K: Padded glove box door. Light charcoal. $10
Title: Delete
Post by: Romeo2k on May 11, 2010, 01:31:05 AM
Awesome stuff!
Still call DIBS on the Halo Head Lamps! :hick:
Do they not come with the Blue Gel Caps?
I should be able to purchase them now, Pending the Shipping Cost~Zip is 98037
Title: Delete
Post by: Clintd on May 11, 2010, 08:11:46 AM
I'll take "G: Headlamp switch with automatic headlamp controls. No fog lamp switch. $10" and "
C: Standard Digital-buttstuffog Cluster for 1985-88 Tbird and Cougar. Lens can be polished with Mcguiars Plastic Polish or equivalent for clarity like clusters A & B - $10"
if still available?
would need shipping to 08859.
Title: Delete
Post by: Watchdevil on May 11, 2010, 10:42:06 AM
Ahh heading off to work in a few minutes... Let me catch up with you guys tonight!
Title: Delete
Post by: 87cougar347 on May 11, 2010, 10:20:20 PM
PM sent
Title: Delete
Post by: Watchdevil on May 11, 2010, 10:33:51 PM
Quote from: 87cougar347;321518
PM sent
PM sent back!
Title: Delete
Post by: Watchdevil on May 11, 2010, 10:37:35 PM
Quote from: 88turbo;321433
PM Sent!
Title: Delete
Post by: Watchdevil on May 11, 2010, 10:48:11 PM
Quote from: Romeo2k;321448
Awesome stuff!
PM sent
Title: Delete
Post by: Watchdevil on May 11, 2010, 11:05:23 PM
Quote from: Clintd;321460
if still available?
PM sent!
Title: Delete
Post by: Watchdevil on May 13, 2010, 07:28:09 PM
Thanks everyone with the interest in purchasing so far! I'll be busy tomorrow getting these things out to everyone who purchased.
Title: Delete
Post by: Watchdevil on May 28, 2010, 10:06:05 PM
This is for dragon574444...
These are the guts of the 1980-82 digital cluster that will swap right into the 83-84 cluster housing.
Second picture will show how the speedo unit will detach from the odometer unit with four screws and unplugging the connectors that go into the speedo sensor in the back of the odometer unit. The odometer will itself detach with the front screws on the light blue plastic front mounting plate. Totally modular so you can replace only what you need to and retain your own odometer with original milege if yours still works good. The odometer I have can easily be reset to the mileage you need if you need to use it.
Title: Delete
Post by: dragon574444 on May 28, 2010, 10:18:30 PM
Hmm. The two aren't 100% identical, but close enough. The 84 speedometer unit has one more terminal on it, and the gas gauge is styled differently. Ironically, the mileage is fine, mine was at 45300. I'll take it though. PM me with a shipping quote as soon as you're able to.
(http://i98.photobucket.com/albums/l280/dragon574444/100_1573.jpg)
(http://i98.photobucket.com/albums/l280/dragon574444/100_1587.jpg)
Title: Delete
Post by: Watchdevil on May 28, 2010, 10:54:37 PM
Quote from: dragon574444;323521
I definitely see the graphics are different on the fuel gauge readout and the speedo unit on yours has the extra fifth connection on the right. I can't tell by the picture what that circuit serves but as long as the first four connections from left to right serve the same functions on your printed circuit then you should have no problem because that is all that was needed for my speedo to operate.
This is the function of each connector from left to right...
1. cluster ground
2. cluster illumination dim (connects to the instrument cluster lights when the headlights are turned on)
3. Speed signal out, presumably for the tripminder option
4. Speedo 12v + on with ignition in run position.
Title: Delete
Post by: Watchdevil on June 07, 2010, 12:56:31 AM
Digital Fuel Gauge for sale!
1980-82 graphics shown but will work and fit fine in any 1983-84 model with digital dash. $10
Buyer Pays Shipping.
Title: Delete
Post by: bike70ride on June 08, 2010, 12:09:53 AM
I'm interested in "F" from dash parts (RH vent).  Just haven't figured out how to get mine out!  Any pointers???
Thx!
Title: Delete
Post by: Chuck W on June 09, 2010, 08:38:31 AM
Sent a PM a couple days ago.
Title: Delete
Post by: Watchdevil on June 10, 2010, 01:08:22 AM
Quote from: bike70ride;324657
Thx!
I got this one out! I am trying to remember exactly though. I believe I started by taking the vent out of the trim. Gently pry on one side until it dislodges from the pivot. As far as the trim removal goes, it's easier with the vent out of the trim. If you notice on the trim, there are tabs. If possible reach from inside the glove box and push those tabs on the bottom of the vent trim. If now you will have to gently pry from the outside.
Title: Delete
Post by: Watchdevil on June 10, 2010, 01:09:11 AM
Quote from: Chuck W;324806
Dude I have been busy and just saw this... Let me get back to you tomorrow.
Thanks!
Title: Delete
Post by: Chuck W on June 15, 2010, 08:21:57 AM
Quote from: Watchdevil;324892
Thanks!
Anything?
Title: Delete
Post by: Watchdevil on July 06, 2010, 11:06:51 PM
Some prices lowered! Get what you want NOW because whatever does not move is getting trashed because I am tired of so many parts laying around that I will never use.
Title: Delete
Post by: joker77_2005 on July 07, 2010, 01:14:27 AM
batch 4
a and d
batch 6
and the crystal headlites
get me a total price shipped to
harpers ferry,wv 25425
if the dash cover isnt to salty to ship then ill take it
mike
Title: Delete
Post by: Watchdevil on July 15, 2010, 02:56:00 AM
Quote from: joker77_2005;327562
batch 4
a and d
batch 6
mike
Did i get you a quote for this already?
Title: Delete
Post by: joker77_2005 on July 15, 2010, 06:58:04 AM
nope been over a week thought all was gone
mike
Title: Delete
Post by: Watchdevil on July 15, 2010, 02:32:53 PM
Quote from: joker77_2005;328337
mike
Very sorry about that I have been busy and must have overlooked this post. I need to respond a little later as I have the day off and need to make a yard run before it gets too late.
Title: Delete
Post by: bike70ride on July 19, 2010, 02:21:03 PM
Quote from: Watchdevil;324891
Hmmmmm, I will have to check into that.  Mine is not really damaged, except for the "slider" doesn't move the vent vanes.  If I could get it out, I may well be able to fix it.
Thanks for the tip!
Is your's still available?  Wouldn't mind a back up just in case...
ship to 66062
Title: Delete
Post by: Watchdevil on August 01, 2010, 01:26:58 AM
Quote from: bike70ride;328805
Thanks for the tip!
ship to 66062
Shipping is usually $5 priority mail for small items. Let me know if you need it. Shoot me a PM!
Title: Delete
Post by: Watchdevil on August 01, 2010, 01:30:34 AM
I apologize to anyone that has not got a shipping quote yet on requests for larger parts or large groups of parts that need to be boxed and shipping calculated. I have not had much time off for the past couple of weeks. I need to find boxes as well. I will try to catch up with this soon!
Title: Delete
Post by: hcor on August 01, 2010, 09:42:26 AM
No problem I'm in no hurry. just hook me up when you get time!
Title: Delete
Post by: Watchdevil on August 01, 2010, 11:59:56 PM
Quote from: hcor;330219
Thanks for understanding!
Title: Delete
Post by: tomsbird1983 on August 06, 2010, 07:31:00 PM
do you still have the 83-84 t bird parts the dash cover i need.
Title: Delete
Post by: Watchdevil on August 26, 2010, 01:27:03 AM
Quote from: tomsbird1983;331005
I missed this post... yes I still have that plastic dash overlay... It has never been used.
Title: Delete
Post by: Watchdevil on September 24, 2010, 03:33:20 AM
Pending sale on some items...
Title: Delete
Post by: 347Thunder on September 24, 2010, 08:37:41 AM
do you still have the headlights I will paypal you right now!!
