Technical => Body/Appearance/Interior => Topic started by: 347Thunder on April 22, 2010, 09:36:17 PM
Title: My new invention for the body moldings
Post by: 347Thunder on April 22, 2010, 09:36:17 PM
I was tired of looking at the side of the bumper so I made these. I was planning on making them it was a little lower on the to do list. So this is the first one only 3 more to make. They will be painted red when I finish the others. What do you guys think?
Post by: DVP on April 22, 2010, 10:17:04 PM
Always wanted to make something similar. A bit longer though. I like the idea. End of bumper trim is one of the ugliest things on these cars.
Post by: CoogarXR on April 23, 2010, 12:03:12 AM
What's it made out of?
Post by: 347Thunder on April 23, 2010, 07:06:50 AM
aluminum
Post by: daminc on April 23, 2010, 07:28:15 AM
I had the same thought, but to cut another matching moulding on a 45 deg. angle and glue it on.
Post by: tbirdsps on April 23, 2010, 12:19:53 PM
I've been going back and forth on keeping or deleting the side trim on my 86 and thought that if I deleted it I wanted to do the same from the removed trim just to transition that area properly.
The aluminum is a good idea too.
Post by: EricCoolCats on April 23, 2010, 01:18:39 PM
Actually I like the aluminum look...it's kinda "fancy". ;)
For years (actually, decades now......) my mind has been struggling with a way to cap off the molding, especially when it's left off between the bumpers. In the end my eye wants to see all the factory molding on. Don't know why, it just looks cleaner to me. I like the removed molding look, it's just that with the molding built into the bumper covers, there's not a super practical way to remove it and make it look 100% clean. This aluminum bit is the nicest solution I've seen though...very cool.
Post by: tbirdscott on April 24, 2010, 04:24:02 PM
I have a set of those for my box bird, they were made by ford though, they go behind the front bumper instead of the chunky urethane pieces that usually go there.
(http://i68.photobucket.com/albums/i11/turbosprunt/100_0375.jpg?t=1272140423)
I agree with Eric that it just looks better with the trim in tact, unless your is ruined and srewed on like my cougar...
Scott
Post by: jkirchman on April 27, 2010, 11:05:34 AM
I like the way they look, but I'd have to see a picture of the entire car to decide for sure.
Post by: 347Thunder on April 28, 2010, 04:43:01 PM
just some spray can color mach paint, color is a little off so I will mix up some base clear and spray them. Only two more to make:punchballs:
Post by: 347Thunder on April 28, 2010, 04:44:24 PM
1 more
Post by: hypostang on April 28, 2010, 04:47:58 PM
They look good :D
Post by: sarjxxx on September 01, 2011, 03:26:25 PM
heck yes
Post by: 347Thunder on September 01, 2011, 04:45:52 PM
oops I never posted pictures of the finished product, coming soon
Post by: 347Thunder on September 01, 2011, 04:59:51 PM
a few, not the best pictures but the look great
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/IMAG0324.jpg)
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/IMAG0322.jpg)
Post by: mtgmike on September 01, 2011, 05:18:54 PM
I was a little skeptical when I first saw these, but that looks fantastic painted. It really looks like a proper stopping point for the trim. Great job.
Post by: 347Thunder on September 01, 2011, 05:47:20 PM
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/DSC06590.jpg)
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/DSC06591.jpg)
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/DSC06592.jpg)
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/DSC06593.jpg)
(http://i174.photobucket.com/albums/w92/03grinnie/T-bird/DSC06594.jpg)
Post by: bryan163 on September 01, 2011, 09:57:33 PM
Looks good. I left the hard plastic sections on mine and deleted the rubber sections. I didn't mind the look of the trim, but it got a little distorted when I took it of to paint the car so I just decided to leave it off. Has anyone ever seen any nos pieces for sale?
Post by: thunderjet302 on September 01, 2011, 11:20:15 PM
Quote from: bryan163;366609
There is any easy fix for the warped molding. If you remove the aluminum backing from the vinyl side molding it will lay flat again. Then all you need is some heavy duty 3M molding tape and you're all set.
Post by: bryan163 on September 02, 2011, 06:22:17 AM
I will definitely give it a try. I didn't know there was an aluminum backing. I gotta go dig those out of my garage and revisit this. It really doesn't look bad with the moldings terminated at the wheel wells either though.
Post by: 86sonicbird on September 06, 2011, 12:13:36 AM
looks good
Post by: GDawg148 on January 04, 2016, 06:55:03 PM
Just came across this thread.. this is amazing!  I would love do have something done like this for my rear bumper, but I'm not very.... "crafty".
Post by: Haystack on January 05, 2016, 02:20:22 AM
I think you could do something similar with the stock plastic trim cut down with a hack saw and some epoxy.
Post by: jcassity on January 05, 2016, 08:15:21 PM
I like this nod,,
missed this thread somehow
Post by: GDawg148 on January 05, 2016, 09:13:56 PM
Quote from: Haystack;453231
Good point.  Might be a cool project for my '88 in the future.
Post by: ZondaC12 on January 06, 2016, 01:00:22 PM
I remember seeing this, never thought to comment. Calls to mind old wraparound bumpers that did just "end" but with a rolled/tapered finish like that. Very factory-appearing!
Post by: ccassity on January 06, 2016, 09:24:35 PM
i like it alot. was it C&C machined or did you just get fancy with an angle grinder?
 either way, very impressive work!
Post by: 347Thunder on January 06, 2016, 09:35:14 PM
Port-a-band saw and bench mount belt sander
Post by: Drewstang on January 14, 2016, 03:13:24 PM
Want to make any more, lol?
Post by: 347Thunder on January 14, 2016, 04:23:10 PM
They took about 1-1.5 hrs each,  funny thing is I thought the other 3 would be easier. Lol
So the answer is heck no...how much are they worth?
