Yeah that cooky but neat 70's fad I think will look cool on my 86 Thunderbird. So far Ive only found them for vans and Mustangs so I need to do some measuring to see if some of them might fit my Thunderbird. What do you think?
Someone here has them on an 87-88 but just who is eluding me right now .
Hopefully they will chime in
For me they only look decent on classic Mustangs. I had a set on my 1985 Camaro IROC-Z one time on that big wraparound glass hatch. I only got them to keep the interior cooler.
I believe you are thinking of 83Heritage
I think that would be 1Bad88tbird
And of course 83Heritage has them on his '83
I really like the look and function of them, just wish they were easy to find and reasonably priced.
I had them on, they were only held on with double sided tape, and after a couple of years they came loose. Got tired of messing with them so I removed them.
Hey yeah I've got a set on my 88. I think I've had them on it for 15 or 16 years now. For me it wouldn't look right without them, it's been so long. I've tried to see if they're still available with no luck, and someone else was supposed to be doing a search on them as well but I've not heard anything for a while. Here's a pic. if you've not seen it.
Those are kinda cool. I wonder how they'd look on a four-eyes.
yeah Ive been doing some research to see if anything comes close to it but since my 4 eye's rear window is so curved a Mustangs one doesnt really fit. But they do look bad ass, 1badd88tbird
hey 83heritage, what did you do with those louvers you took off?
I still have them. I was researching using some epoxy or rear view mirror glue to hold them on. Never really came up with a good solution.
That looks great! I want a set! :) I'll give you a shiny quarter for yours :). :rollin:
I was offered $300 at the Carlisle All Ford Nats. a couple of years ago. I was like yeah right. I couldn't get rid of them, like I mentioned my car wouldn't look right without them.
Mine are on with 3M double stick tape. The main piece across the center is on tight, I've never had a problem with it. The four tabs on the sides I've had trouble staying on. I ended up putting a couple layers of the tape on them and sliding an end under the weather stripping. Plus I've fitted the bottom of the louvers under the weater stripping. That keeps the on pretty good.
id buy em from heritage if he wanted to sell em
Not looking to sell them, sorry.
Here is mine:
(http://i22.photobucket.com/albums/b325/Aesthetikz/Thunderbird/tbirdlouvers03.jpg)
(And no i did not make those hideous primer squares)
This was just a test fit right after i received them in the mail (Won em' off of ebay).
I dunno about 83Heritages~But mine has some mounting clips that attach under the trim, As well as the use of double stick tape.
cooool
It sounds like they mount like mine. Are your's metal? They look different than mine. Mine are plastic.
