Technical => Engine Tech => Topic started by: Whiteboy on April 18, 2010, 12:52:55 AM
Title: Wiring diagrams?
Post by: Whiteboy on April 18, 2010, 12:52:55 AM
Ok so when i got this engine, it had alot of stray wires that led to no where on both ends, but i kept them all in case. now that its apart i went to the speed shop to see how much itd cost for a full gasket replacement and compression test, for the assembly,gasket renewal, and compression/fluid test, to make sure it ran fine, it will cost me 500 bucks!!!! I am gunna do everything myself except for the compression test, my question is if there is any diagrams to show where the wires go for anything/everything around the engine...
Post by: 32VFoxBird on April 18, 2010, 09:26:28 AM
What did the motor come out of, and what are you putting it in?
Post by: Whiteboy on April 18, 2010, 12:21:10 PM
Lincoln Mark VII to 88 TBird
Post by: 32VFoxBird on April 18, 2010, 02:04:11 PM
If your car has a 302 in it already, you just use your factory wiring. No need to figure what the wires on the HO motor are for.
Post by: Whiteboy on April 18, 2010, 02:27:02 PM
there isnt a difference? well that will make things more simple.... even the injector harness's and stuff?
Post by: 32VFoxBird on April 18, 2010, 02:44:18 PM
Yes. Only the firing order is different. You'll need to reroute your plug wires. That's it. Read up on coolcats.net for info.
