General => General Fox T-Bird/Cougar Discussion => Topic started by: jcassity on April 26, 2005, 09:30:57 PM
Title: Ive often wondered,, (brake fluid)
Post by: jcassity on April 26, 2005, 09:30:57 PM
Since Dextron III can be fairly universal and could be used as power steering pump fluid,,(mind you ive used tranny fluid for ps fluid going on several years now) why could'nt the brake system be drained and blown out of all fluid and dextron III used? Its not corrosive and we all know how much of a plus that is.
Title: Re: Ive often wondered,, (brake fluid)
Post by: Ifixyawata on April 26, 2005, 09:36:23 PM
I dunno that it could stand up to the temp requirements of brake fluid.
Post by: armyguy298 on April 27, 2005, 12:09:45 PM
I was intrigued at this question and tried to do some research on it. None of the searches I did came up with a comparison of hydraulic fluids to silicon brake fluids. Only differences I saw were that silicon brake fluid absorbs moisture. Why? No clue. I would think a fluid that doesnt would be desireable.
Silicon brake fluid has a very light viscosity. It allows the seals of a brake cylinder or caliper to retract when pressure is released. Thus allowing the brake pad to move away from the braking surface and reduce wear.
I also believe that no matter the temperature, silicon brake fluid maintains its viscosity. Dexron III would lose viscosity the warmer it gets.
Not much help, but certainly an interesting question. One way to look at it is: If it was a good idea, someone would have done it already. But I tend to stick with what works. :toilet:
Post by: Chuck W on April 27, 2005, 01:59:26 PM
You'd boil that ATF right out of the system......
Post by: JeremyB on April 27, 2005, 02:52:32 PM
Quote from: armyguy298
Silicone (DOT 5) fluid does not absorb moisture. Glycol (DOT3,4.5.1) based fluid does. DOT 5's boiling point does not decrease as moisture enters the system. The downside is that moisture can gather at low points and corrode the system. Also, if moisture enters at the caliper seals, that fluid now has a boiling point of 212 deg, much lower than DOT 3,4,5.1 fluid with moisture contamination. DOT 5 fluid also has poor compressibility characteristics that change with temperature and foaming issues. For a daily driver, none of this really matters, but DOT 5 does not belong in vehicles going to OT or HPDEs.
Post by: Thunder Chicken on April 27, 2005, 06:21:07 PM
Here's a real big reason to never put Dexron III (or any other transmission or hydraulic fluid) into your brake system: You will completely, utterly and royally bone your complete brake system. Master cyclinder, proportioning valve, calipers, wheel cylinders and rubber hoses - every one of 'em would be screwed ON CONTACT!
The rubber that is in a brake system is a special kind of rubber that is not compatible with petroleum based oils. Tranny fluid will soak into the rubber components, causing them to swell to several times their normal size. This would cause all of your components to seize up, and your hoses to swell shut. You would not even be able to get the cap back on the master cylinder once you took it off. And there is no repairing any of it. All of it would have to go, and your steel lines would have to be thoroughly flushed.
Never, ever let any petroleum-based (or synthetic petroleum-based) fluids anywhere near your brake system!!!!!
Post by: dominator on April 27, 2005, 06:25:52 PM
Agreed!
Post by: merccougar50 on April 27, 2005, 07:41:43 PM
Much like the morons who accidently put used motor oil (or something else) in, to top up the MC.
Post by: tbirdscott on April 27, 2005, 08:49:47 PM
Quote from: Thunder Chicken
So how bad of a thing is it that my tranny line blew and soaked my brake hoses a few days ago? should I expect to have to replace them soon or what? (if you look closely you can see the sheared off sway bar mount on the drivers frame :disappoin ) this was two days after I replaced the 4-piece drivers coil, been spending a lot of time under there lately :yuck:
Post by: Thunder Chicken on April 27, 2005, 09:24:50 PM
Quote from: tbirdscott
Oil on the outside, while not particularly good, is not particularly bad either. The outside of a brake line is made from a different rubber than the inside
Post by: tbirdscott on April 27, 2005, 10:30:49 PM
good ta know! thanks
Post by: jcassity on April 27, 2005, 10:38:36 PM
Ill buy into the whole swelling of seals and stuff cause that makes sense.
the issue about the fluid getting too hot,, makes me wonder... Its not like the tranny fluid never gets hot cause it does and infact requires routing to the radiator for a cooldown.
Post by: Chuck W on April 28, 2005, 12:29:35 AM
The seal swelling is the major factor...didn't think about it while I was at work.
The trans fluid never really gets as hot as a brake system can..esp when driven hard.... The std petrolium fluids aren't made to work at much over 230* for very long. Brake fluid on track cars can get to 500*+...I've seen guyshiznit the track with uprated pads and such and forget to uprate the fluid to a high-temp version...then they wonder where their brakes go after several hot laps.
Anyway...yeah, use brake fluid for brakes :hick:
Post by: amooset on April 28, 2005, 03:59:17 AM
Tranny fluid must be the ketchup of fluids. Use it on about anything. What next? Replace your coolant with it? :giggle:
Post by: jcassity on May 01, 2005, 03:49:30 PM
i still dont understand how brake fluid gets hot for prolonged times. Sure the caliper gets hot and transfers the heat but ive never ever noticed my brake fluid resivoir boiling over or my brake lines being hot to the touch, or the fluid in the resivoir being hot either :giggle:
btw,, i needed about 3/4 of a qt of oil the other day and all i had was tranny fluid. I dumped that in there to get the oil to the full mark. been like that for a few hundered miles so far and actually ran quieter. Not suggesting anyone do this,, i just dont really care what i do to experiment on my "own" stuff.
Post by: Thunder Chicken on May 01, 2005, 04:18:12 PM
You're actually cleaning your engine with that bit of tranny fluid in there, so goes the legend. I've heard of people running a quart of tranny fluid in with the oil to de-sludge the engine. Whether it works I dunno, but I don't think it does any harm...
Brake fluid gets very, very hot, but not in the reservoir. It gets hot in the calipers and wheel cylinders. The lines are too thin and too far away to transfer the heat to the M/C reservoir. Just try touching a caliper after some serious driving (you will burn yourself, so be warned). Of course you'll never see it boil in the reservoir - that's the whole point of brake fluid. It doesn't boil (at least at normal brake operating temperatures). When the fluid does boil it will create "air" in the lines (it's not really air, it's brake fluid vapour) which will cause a loss of braking power because the vapour compresses. When everything cools down the vapour usually re-condenses into fluid and your pedal comes back.
Tranny fluid gets very, very hot too, and it can withstand a whole helluva lot of heat. Just take a look at a torque converter that's been turned blue with heat. That blue is from the fluid heating it up. Of course the fluid does get destroyed when it gets that hot (which is why trannies use coolers), but it does get very hot.
Post by: Bird351 on May 01, 2005, 04:26:37 PM
Here's a post from over at FTE in the Inline Six section:
Well, to start off, I bought this truck a year and a half ago. Ran fine, but when I would get up to temp, it had a harsh lifter ticking. I have run Motorcraft 15-w40 Powerstroke oil since I got it. The ticking kept getting louder, only audible from one or two lifters. I was advised to run ATF through the engine for a couple of oil changes by a friend, but over time, the ticking only got worse, and now all of them are rattling. As of late, since this winter, I have been annoyed by low power output, pinging under load, and an intense "Diesel" rattle when engine is running at cruising speeds, and when I level off for my next shift. I try to keep this time of sustained engine speed to a minimum, but I need to fix it. It will "load up" if let idle for a couple of minutes. What I am wondering is if the lifters are all bad, and I am not getting proper valve lift, not allowing the engine to breathe correctly, or if the cam is going flat. I am almost out of John Deere Diesel school, and don't have enough money to put lifters, pushrods, and rocker assemblies in, let alone a cam. I was also wondering what the valve lift specs on an '85 300 are. Any advice would be helpful.
Post by: black ct on May 01, 2005, 07:42:18 PM
I've run ATF in several engines on occasion, Usually to clean them out. ATF is supposed to be an excellent lubricant and has built in detergents. In my old Beetle, before a rebuild, I drained all the oil and ran it for an hour with just ATF. That engine was spotless afterward when I tore it apart. In fact it looked like I had hot tanked it! I also know an old Buick guy who always runs a pint of ATF in his oil. His cars run like tops. My 67 Impala had a lifter noise that dissappeared after the old ATF treatment as well. Just don't overdo it. Except in the case of my Bug that was getting a rebuild anyway. On occasion I also put a 1/2 pint of ATF in my gas tanks to clean the combustion chambers/valves - Never had a problem yet, Just something I learned from the old guys.
I am not suggesting anybody try this.... I'm just sharing what I do to my own stuff. :canada:
Post by: tbirdscott on May 02, 2005, 01:43:20 AM
Quote from: blakct
Them grey beards know a thing or two! i've done the same thing before to clean engines and injectors, etc. works great in my experience.
