General => General Fox T-Bird/Cougar Discussion => Topic started by: Sean Story\1988TURBO on April 11, 2010, 07:39:10 PM
Title: clutch, and stuff uuuhhhh
Post by: Sean Story\1988TURBO on April 11, 2010, 07:39:10 PM
i was driving my tc that has been on the road for about 5 mouths. i was running her to a point because my tcs speedo and tach and some other things arnt working due to im guessing a fried wire. but any way felt kinda lagy. so i tested it and looked for vacuum leaks and turned out it was getting worse. i discovered driving it more was the old beat up clutch that i learned to drive on is almost gone. i was cruising and can to a hill and tore up the clutch even more, are top speed limping home was 45 MPH from seaford De.. i need to change the clutch soon because i need to get my wiring  finished and it will be a perfect running car what clutch should i put in, part numbers would be welcomed. i have a K&N filter and a 3' stinger exhaust. so does that change up the game lol
Post by: Chuck W on April 11, 2010, 07:46:52 PM
How about posting  something intelligible?
If you have a clutch question, post it in the proper forum location.
