im needing a few of the small pan bolts from a 5.0. small request thanks
needing these rather soon. will pay shipping
What about the local Lowe's?They have all kinds of bolts,and they work great...and cheap....and fast.....
true, but I'm kinda picky about my hardware I like to use factory as much as possible
I have a whole set of Explorer bolts (NICE),but they are too long.The lip on the Explorer aluminum pan is pretty thick.Can you post a clear pic of one of the bolts?I may have some.I have about 40 pounds of fasteners in the garage.IF I have them,I'll send them your way.
will do when I get home. thanks Vinnie
No problem.I'm going to go dig around now and see if any of them look familiar.
Do they have little built on,but loose,washers?I have 9 of them,but they don't look long enough to go through the pan,gasket,and rails.
they are a bolt with a no washer. I almost thought they were valve cover bolts when I gathered them last night.
I'll look again,I probably have them. If I do,how many?
I think I need 2 or 3 here is a pic of the bolt
I think I have some.I'll let you know tomorrow after work.If so,I'll ship them up to you stat.
awesome vinnie!!! still have my address?
if vinnie doesnt have them pm me and i can send you a few
no worries, took a trip to the local yard and pulled a hand full and found an oil pressure sending unit extension! SCORE!! :D thanks anyways guys
Good deal.Glad you got your parts.I need to start pulling those extensions when I see them and other bits and opieces.Time to make a small warehouse of parts..
