Found shifter boot and pedal.
I actually have a shifter boot,no tears in it,but it needs the plastic insert for the inner top.I may grab some pedal assemblies when I hit the yard.There were two or three out there.
Hey if I find out that my transmission needs too much work I may swap out for a manual. Since it will never be a daily driver it might be a fun break from an automatic.
Vinnie - Send me a PM with what you think a pedal assy is worth, and I'll let you know.
Watchdevil - I'll sell you my C5! Then you can get rid of that nasty AOD. It will only cost you about 5-8MPG, but what would you care, it's not a DD! Lol j/k.
I have 85/86 turbo coupe pedals clutch cable, cross member and steering coloum too ( just so you will not have the old auto shifter hanging there
Do you know if the clutch linkage they were used with was hydraulic or cable operated? I might be interested in the pedals and the steering column covers, but only if they are red.(The covers that is)
I have both sets of pedales, hydro or cable.. wich would you perfer?
Ill look for red covers, I know I have the grey/blue/raven
Looking for cable. Definitely let me know if you find red covers. Would probably be best off an 83 though.
do you have a cable bell for the 3.8 engine?
