Just curious, anybody know what kind of cfm a 70mm TB flows?
Searched the net and couldn't find much ifo on 60mm,65mm or 70mm cfm#s.
http://www.accufabracing.com/Flow%20Data.htm
They don't have a listing for the stock 60 MM throttle body, but it flows around 550 at 28" barometric pressure
Cool,the only problem is,what would be my approx baro and were would i find it?
Is it not 14.8 at sealevel?
14.8 is pressure at sea level otherwise known as 1 BAR.
The way it's measured in the chart is by inches of mercury.....
Well, 28 in H2O (that's what they are using) is about 1 psi drop across the TB. It is standard to use 25-28 in H2O to compare flow rates - so I would use those figures.
AHHH I thought they measuring air pressure. My mistake.
Cool,so about 650-700cfm?
On Accufabs page... Anyone notice????
STOCK 58 & 60mm, test results not available..
Accufab 65mm RACE, test results not available...
I believe they don't want you to know what they are... But they slipped up..
Accufab 65mm, 664cfm @ 28"... (and at the bottom of the page)Stock Explorer 65mm 680cfm @ 28". So their aftermarket 65mm is not as good as the stock Ford piece???
