I'm looking for a stock throttle body spacer for my 5.0
The Previous owner snapped a bolt off for the throttle cable bracket and messed it up pretty bad trying to remove it and then (glued? epoxied?) the head back in place so no one would notice :punchballs:
I could probably drill it out and put a nut and bolt in in if I have to because it is the lower bolt hole but I would rather not
I have one as soon as I get it loose from the intake.
SWEET !!!!!
I'll wait here ...lol
how soon do you need it? not sure where I put my pipe wrench. those studs are pretty corroded :(
Im not in any hurry at all , whenever you have time
sounds good, I'll let you know when I get it removed. Thanks
turns out the one I have is from a lincoln and is different :(
Bummer
Thanks for checking though
no problem.
