Technical => Engine Tech => Topic started by: Thunderbus on February 24, 2010, 08:34:56 PM
Title: new turbocoupe
Post by: Thunderbus on February 24, 2010, 08:34:56 PM
what psi will a ihi run without destroying the bearings?
what does it mean when the car starts julting at high boost?
88 tc 5 speed
Post by: bigbada1 on February 24, 2010, 08:50:59 PM
I'v ran 18 with no problems 15 is factory
I had the julting at high boost problem and it was solved with a new propeerly gaped set of plugs and new wires
Post by: 88CougarGT on February 24, 2010, 11:16:32 PM
Quote from: bigbada1;311392
x2.  Your probably blowing out your spark.  Try a new set of quality copper plugs.  If it still has it, try under-gapping them some.
Post by: BogusSVO on February 25, 2010, 03:40:57 PM
autolite spark plugs 764 or AR764 if you can get them, and the best set of plug wires
also check your fuel pressure, make sure it is 39-43 psi with the vac hose off
15-18 is all the lil IHI is good for
make sure you have the bracket on the front of the IC on and bolted tight , and that the IC coupler clamps are snug
Post by: croga001 on February 27, 2010, 10:50:44 AM
i think everyone here was saying do not stray away from motorcraft parts when it comes to spark plugs and wires.  i bought mine from http://www.forced4.com/svostore.html along with the cap and rotor.  my car ran great after that.
Post by: fordguy545 on February 27, 2010, 12:43:32 PM
Yep stay with motorcraft wires for sure on stock ignition.  I put a set of taylors on and it ran AWFUL going down the road.  It would spit and backfire everyso often and was annoying.  Drove it 10 miles like that and went back home and got a different car till I could switch it back.
Title: pic of the turbocoupe
Post by: Thunderbus on March 01, 2010, 03:20:10 PM
http://s817.photobucket.com/albums/zz96/midgittyson18/tbird/
