Marketplace => T-Bird/Cougar Parts & Cars FOR SALE => Topic started by: 85turbotbird on February 04, 2010, 04:43:17 PM
Title: 1987 Thunderbird Turbo Coupe SOLD
Post by: 85turbotbird on February 04, 2010, 04:43:17 PM
SOLD
Stepdad said he wants to sell it as he doesn't have the time to do anything with it since he's been working up in Northern NJ so here goes:
I'm listing my 1987 Ford Thunderbird Turbo Coupe (5 speed). Listing it simply because I haven't had the time to do anything with it and I'd rather see it go to someone who has more time to work on the car than I do. The car is in good shape with a very straight body and lots of new parts. The car is going to need front brakes soon and also is in need of sway bar frame bushings. Windows were tinted to 15% (front/side/rear/front brow) by dynamic tint in NJ. Drivers side door panel lower arm rest cracked in half so I threw it out, but kept the top of the arm rest as it was in good shape and also the door lock cover panel. Car comes with spare speaker covers, 2 PRS struts, 1 shock, 2 rear side windows and some other misc stuff. The car also has the map pockets, but they're not installed & will be included. In the photos you'll notice that 1 of the fog lights is missing..it's not missing, it's just in the trunk while I replace the bulbs. It will be installed prior to being sold. The car has approximately 113,410 miles or so, but that number is low because of the bad speedometer drive gear or speed sensor (1 of the 2) that was replaced by the previous owner so that car probably has 140-150,XXX. Car is inspected until 5/10 or 6/10 (not sure of the exact month) in PA.
Please don't mind the road dust on the car as the weather in SE PA has been rocky over the past few weeks.
The car was tuned by Brian Larkin (BJL) from TSTACC & NATO a few months ago
Here's a list of parts added to the car by the previous owner and myself:
PREVIOUS OWNER-
Brakes - 18 months ago
Tires - maybe 6-7k on them
Walbro 255 fuel pump w/correct sock - 2 years ago
Gas tank- 2 years ago
Rack and pinion - 12 months ago same for the rest of front end parts
Ball joints
Control arm bushings
Sway bar end links
Alternator
Belts
Ignition switch -2 years ago
Clutch Pressure plate pilot bushing 4/10/09
Trans Mount
Rear main seal 4/10/09
Speedometer drive gear 4/10/09
Speed sensor
PRC struts - came off a parts car that had receipt after accident 26k miles on them
AC converted to R134
Radiator - 2 yrs ago
Heater core - 2 yrs ago
New Ford headlights - 1 year ago
ME-
Oil change- 110,500 (Mobil 1 5w40 turbo diesel oil with bosch oil filter)
Plugs- Autolite 764 (111,500)
Wires- Motorcraft (111,500)
Cap- BDW (111,500)
Rotor- BDW (111,500)
Pcv Valve- Motorcraft (111,500)
Timing belt (111,500)
Fuel filter- Purolator (111,500)
See photos here:
http://gallery.andrewshemo.com/index.php/Miscellaneous-Photos/Cars/turbo-coupe
Contact me- Andrew @ 610-809-2316 or by PM
I'm located in SE PA near Philadelphia
Post by: 28HopUp on February 04, 2010, 09:17:13 PM
Free bump for a nice looking TC.  Good luck with the sale Andrew.
Post by: 85turbotbird on February 05, 2010, 12:13:22 AM
Quote from: 28HopUp;309248
thanks man.  I just have to come to grips that I'm just too  big for turbo coupes.  between my stepdad and I we've had 5 TCs and I love them..maybe one day when I lose some weight I'll pick up another or maybe a nice SC or just a simple LX!
Post by: Chuck W on February 05, 2010, 07:24:53 AM
Read rule #4 and update your ad or profile pls.
Post by: 85turbotbird on February 05, 2010, 06:39:37 PM
Quote from: Chuck W;309287
read the title-
1987 Thunderbird Turbo Coupe $2300 OBO SE PA
under my username it also lists me being in Pennsylvania.
I'll add it in the actual ad again since some folks can't seem to read the title.  :mad:
Post by: Chuck W on February 06, 2010, 02:53:30 PM
Quote from: 85turbotbird;309357
read the title-
NO, YOU read rule #4...CITY AND STATE required for ALL ads.
If you don't want to follow the rules, you don't have to post things for sale here. End of discussion.
Post by: 85turbotbird on February 08, 2010, 02:55:12 PM
Quote from: Chuck W;309468
done.
