Technical => Body/Appearance/Interior => Topic started by: Thunder Chicken on April 21, 2005, 09:08:56 PM
Title: LED tail light project finally moving ahead...
Post by: Thunder Chicken on April 21, 2005, 09:08:56 PM
The LED tail light project is finally underway again. A brief history: I've wanted to do this mod for years. I drew up a concept picture about four years ago, but never did anything with the idea:
(http://www.foxthundercats.com/leftledbrakelight.jpg)
 About a year ago Crystal sent me a pair of tail lights out of her defunct TC (I did not want to wreck the only pair I had, which were on my car). When I got those housings, in a fit of unbridled ambition I took 'em apart and cut out the red lenses with a dremel:
(http://www.foxthundercats.com/ledtails/tailmod2.jpg)
Then the project went on hold for several moths. Finally, today, I decided to work on it a bit more and actually got a light module done:
(http://www.foxthundercats.com/ledtails/tailmod3.jpg)
(http://www.foxthundercats.com/ledtails/tailmod4.jpg)
I was originally planning on using 100 superbight LED's per module, but that proved to be too many (too bright) so I settled on 55. I also decided against the blue dot - no point in attracting unwanted attention. Now I only need to make up five more red ones and two white ones (the white ones will have 100 LED's each and will be square), then put it all together, and then finally I will have the coolest (both literally and figuratively) tail lights on any 87-88 Bird :D
Title: Re: LED tail light project finally moving ahead...
Post by: dominator on April 21, 2005, 09:41:26 PM
Sweet project man but just a thought,truckers use those round led modules on there trailers and for tailights,would the modules fit in the holes that you made?
Post by: oldraven on April 21, 2005, 09:44:48 PM
I hope you get them done by my birthday, because I honestly couldn't think of a better gift. ;)
Post by: baxo on April 21, 2005, 09:46:44 PM
That's very impressive man.. way to go!
Post by: Thunder Chicken on April 21, 2005, 09:54:05 PM
Quote from: dominator
I thought about those truck lights, but at $40-$60 apiece it would be a very expensive proposition. Pllus each of the three holes are actually a different size in these cars (the one pictured is the smallest). Besides, I wanted to do it my way :D These lights will go back together in the stock housings and mount just like stock lights.
Oh, and each LED has to be angled down due to the slant of the tail lights, otherwise they would point into the sky. Truck lights point straight ahead, so the only one that woould see 'em would be airplane pilots :crazy:
Post by: Blck85TBirdV8 on April 21, 2005, 10:38:21 PM
nice project. very impresive. have you thought about doin LED's for the 3rd brake light?
Post by: Extinct on April 21, 2005, 10:57:15 PM
They look awesome specially with the sequencials, when will the kit be ready for marketing?:)
Post by: Tbird232ci on April 21, 2005, 10:59:54 PM
plus, the trucks use ones with less, larger LED's
very good looking dude
Post by: Thunder Chicken on April 21, 2005, 11:07:09 PM
I've already got an LED lamp module for the third brake light (it was actually a Federal Signal LED police light designed for Crown Vic third brake light housing), I've just gotta install it.
The LED tails will feature built-in sequencers, of course :D But don't hold your breath waiting for me to start selling 'em - the amount of work involved coupled with the total lack of cores (tail light housings) available around here would make them hella expensive. Hell, it took me three hours to make that one lamp module (though I was making it up as I go - the next five will go much faster).
Post by: cougarcragar on April 21, 2005, 11:44:43 PM
Nice work, Carm.
Maybe we can share ideas on how to illuminate the panel on my '96. If we can come up with a plan, you could sell the kits on tccoa and make some money.
I was thinking of EL panels, but I don't think they would be bright enough. I'm worried that LEDs will create "hot spots" on the panel. It's very shallow.
Post by: Thunder Chicken on April 22, 2005, 12:02:11 AM
Zach: By "hot spots", do you mean heat? If so that's not a concern as LED's run very cool. If you mean bright spots, about the only way I can think of around this is to get "inverted cone" LED's that throw the light back toward the base. If you did this and painted the base in a reflective color you should get a nice, evenly lit back panel. This is assuming that you can separate the red lens from the base in the first place...
The late T-Birds with backlit panels used a row of LED's along the bottom pointing straight up, but the optics in those are likely different than the Cougar.
Post by: cougarcragar on April 22, 2005, 08:36:06 AM
By hot spots I mean bright circular sections on the panel.
I once rigged up my own 12v light bulb in a burned-up EL coach lamp about six years ago. The center of the Cougar head was very, very bright. It was obvious there was a light bulb in there.
I was able to cut out a circle of plastic from a jewel case and scuff it up with sandpaper. This diffused the light much better (along with the factory diffuser plate).
Using LEDs from the T-Bird panel isn't really an option. They're very unreliable and always in high demand.
I've always messed around with LEDs in the past, but I've never seen the "inverted cone" LEDs. Very cool stuff!
I can recall mooching the cheap red LEDs from christmas toys and decorations back in the day, then wiring them up to a model car or something.
Recently, I've worked with the bright "SMT technology" LEDs, which are clear in their off-state. I was thinking about using those for a panel.
Post by: Thunder Chicken on April 22, 2005, 08:52:08 AM
Here ya go: Inverted cone LED's (http://"http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=26207&item=7508961379&rd=1&ssPageName=WDVW")
When I get to the cutom cluster project I'll be using inverted cone LED's for backlighting.
Post by: Snubz-N-Ttown on April 22, 2005, 11:43:55 AM
I was thinkin about doing something like this but with the new led brake lights found in most tractor trailers now. keep us posted
Post by: Tbird232ci on April 22, 2005, 11:47:30 AM
Zach, if you want me to, i could possibly find you the LEDs fron a 96-97, which are the better years for the LED's, theyre in and out of the junkyads, and if the lenses are broken, i dont mind yanking apart, the ones that are in good shape are worth too much money
Post by: Thunder Chicken on April 22, 2005, 03:58:37 PM
I've still got one more conundrum: Do I paint these things (pictured with only one side cut out) :
(http://www.foxthundercats.com/ledtails/tailmod1.jpg)
black (like stock), silver (like ricers), red (like tail lights) or white (like the car)? They'll be behind factory tinted lenses. Regardless of the color, the round things (and square backup light thing) will be black because that's the color of the resin "potting". What do y'all think?
Post by: nirvanagod on April 22, 2005, 04:02:04 PM
Black for sure.
Post by: oldraven on April 22, 2005, 05:00:15 PM
Black.
But more importantly, nice real hardwood floors, man. :D
Post by: thundergrowl on April 22, 2005, 09:16:45 PM
I'm thinking white.
With all the work you're putting into these custom lights I would think you'd want them to stick out a little.
Black would look stock to the uneducated eye. Like you said, silver would make them look ricey and stick out for the wrong reason. Red would blend in with the LEDs.
White (body colour) would highlight the LEDs and the round taillights (one of the reasons I like the 87/88 t'bird) The tinted lens would define the taillight from the body. Yes, white, white, yep, white.
Post by: oldraven on April 23, 2005, 12:21:57 AM
If you go white, you should mould them into hte body, with the led's having their own round covers. It would give you a look like a Vette, or IS300. Super hot, I think. Otherwise, if you're keeping a traditional lens, go black.
Post by: Beau on April 24, 2005, 02:20:43 PM
as an owner of a white Bird, I also agree for white, but do as oldraven suggests, it'll be bitchin' hot.
Post by: Thunder Chicken on April 24, 2005, 04:20:01 PM
The molding into the rear ain't gonna happen - I am to bodywork what William Hung was to good music and common sense, and I certainly ain't gonna pay somebody to do it.
I think what I'll do is paint one white, mock it up, and see if I like it. If I don't I'll paint it black.
Post by: chrome302jr on April 25, 2005, 09:41:48 PM
Thats pretty hot, good work.
