so my clutch on the old compressor looks like is gonna fall off or fly off when engaged . so how do i go about changing it. i have an Extra compressor. so i'll try the removal of that clutch first .
5.0 car (mustang if it matters.)
Erik
Remove the bolt in the front of the pulley, should just slide off. Mine did, but you may need a puller.
Also there are a small washer or two under the bolt, don't loose them very important.. Sets the air gap on the cutch assembly, should be about .015...
cool the one i have must be rusted on . thanks.
btw cool sig pic.
I had to use a puller to get mine off. I used one for a Frigidaire A-6 because that's what I already had on hand. The threads didn't fit exactly, but it worked.
it came off after soaking a day or two with some wd40 sprayed on it . still havnt changed it though.
