Technical => Engine Tech => Topic started by: dgmann995 on December 15, 2009, 01:17:06 PM
Title: 88 turbo coupe problem
Post by: dgmann995 on December 15, 2009, 01:17:06 PM
hey my car build 10lbs boost but feels a little slugish after 3000rpm only code was brake on off falt
Post by: Chuck W on December 15, 2009, 01:56:07 PM
Yeah...that's vague.
Could be any number of things.
Since we don't know what else you've actually done to the car yet (tune up? timing?) all we can do is guess.  At least you ran codes though.
More information (and punctuation) please.
Post by: dgmann995 on December 17, 2009, 08:27:20 AM
it has new plugs wires cap rotor timming set to 10 degrees umm new alterater sorry for the spelling no thermastat right know but putting one in today cat is puntched out thats all i can think of right know oo yea when the motor is cooled runs good sometimes wonce builds above 6 lbs boost loses power.
Post by: Beau on December 17, 2009, 12:18:06 PM
, and . still work!
Post by: dgmann995 on December 17, 2009, 05:30:22 PM
ok?
Post by: dgmann995 on December 17, 2009, 07:02:12 PM
i just found the wire in foil running to the tfi conecter
cut off what does it run to?
Post by: croga001 on December 18, 2009, 11:46:40 AM
id need to see a pic to know what oyu are talking about.  have you changed air filter?
Post by: 86caprirs on December 23, 2009, 06:03:02 AM
Need to see pics too. There is a braided wire that wraps another wire and just ends in the foil. You should not disturb the foil though. I had a 87 Tbird that ped out at the 2800-3000 rpm mark. It would pull hard then hit a wall.it still said 10 psi but I would have to back off the throttle for it to run right. Turned out there was a TSB or SSM from Ford for that problem. It needed a new PCM. That fixed the problem for me.
Post by: dgmann995 on January 03, 2010, 09:33:51 PM
i think my problem is my Idle Air Control it sticks ever once and a wail rpm stays at 3000 rpm so i shut it off and will not start back up till it get cold or i unplug it.
Post by: 86caprirs on January 03, 2010, 09:52:15 PM
Could be the TPS too.
Post by: Chuck W on January 03, 2010, 11:17:07 PM
The IAC has nothing to do with how the car runs, it just controls the idle.  It's probably dirty, which is causing your occasional hanging idle.
How did you set the timing?  Did you do it the SPOUT connector unplugged?
What color is the wire that's cut?  The signals between the ECU and the TFI module run inside the shield (the foil).
Please work on your punctuation, etc in your posts.  Hard as hell to follow you.
Post by: dgmann995 on January 04, 2010, 11:54:08 AM
i used a timming light the spout was out during timming set at 10 degrees and im just putting a whole new throttale body with new tps and AIC on it got it off my spare motor and that wire is bare and covered with foil and it shinny ha ha sorry.
Post by: TurboCoupe50 on January 04, 2010, 07:12:26 PM
Quote from: dgmann995;305090
is bare raped in foil
I think you either need to learn how to spell and use a little punctuation, or report this to the proper legal authority...
Post by: Beau on January 05, 2010, 11:41:38 AM
Quote from: TurboCoupe50;305150
He tried...Chuck told him to use better punctuation :rollin:
That right there is sig worthy, imo...
