Technical => Engine Tech => Topic started by: the_intimidator03 on December 09, 2009, 03:31:07 PM
Title: freeze plug questions
Post by: the_intimidator03 on December 09, 2009, 03:31:07 PM
well i beleive i popped a freeze plug.  ( see this thread for cause http://www.foxtbirdcougarforums.com/showthread.php?t=26487 ) my question is how much room is there to possibly change freeze plug without pulling the motor... it is an 86 302. the coolant is pouring out from passenger side onto cross member.  So i am thinking mid/rear passenger freeze plug.  I am thinkin that if i can pull the manifolds and exaust off.. i can get to it with enough room.  then just slap the headers i have layin around from mustang on there which shouldnt interfere with my column shift and have a couple pipes made for it.
        any help is appreciated
Post by: tbirdsps on December 09, 2009, 04:02:37 PM
Quote from: the_intimidator03;301869
My wife's 3.8 had leaking freeze plugs from corrosion.  I had a shop do all and they did not disassemble to change them.  They did undo the accesories to do the front ones.  The side ones they said were easy but of course they have a lift and experience.
Post by: the_intimidator03 on December 09, 2009, 04:58:15 PM
well im thinking it should be possible from under the car.  figure maybe toss new exhaust while im at it
Post by: vinnietbird on December 09, 2009, 06:29:12 PM
Get one of the expandable type plugs and you should be able to access it.
Post by: 88turbo on December 09, 2009, 11:29:22 PM
I second the expandable ones. I have used those with very good results. push them into place and tighten the nut. very easy
