Technical => Engine Tech => Topic started by: cyber-junkie on December 02, 2009, 06:36:51 PM
Title: Unknown sensor
Post by: cyber-junkie on December 02, 2009, 06:36:51 PM
I have a 87 TC auto with climate control and have a sensor that is a in-line sensor in the metal coolant line that goes to the heater core and the wire harness that hooks to it goes through the firewall inside the car, like where the heater core is....what is this sensor, it's not the coolant temp. sensor like I thought and the parts houses can't figure it out.
Post by: TurboCoupe50 on December 02, 2009, 07:09:05 PM
Its for the EATC system... As long as your heat works, don't worry about it...
Post by: cyber-junkie on December 02, 2009, 07:31:00 PM
Would that be the "electronic automatic temp. control?
Thanks for the info.
Post by: Haystack on December 02, 2009, 11:34:58 PM
I broke mine when I did the heater core two weeks ago. No issues and no codes.
Post by: thunderjet302 on December 03, 2009, 10:30:40 AM
Quote from: cyber-junkie;300951
Yep. It tells the system when the coolant is hot. That way when you turn the heat on and the coolant is cold the system doesn't blow cold air at you. It waits till the coolant is hot before air comes out.
Post by: softtouch on December 03, 2009, 04:05:06 PM
Quote from: thunderjet302;301020
Right!
It keeps the outside air/ recirculate door in the recirculate position and keeps the blower off until warm.
Post by: softtouch on December 03, 2009, 04:12:39 PM
Right!
Post by: thunderjet302 on December 05, 2009, 10:44:01 PM
I wish the ECC in my 95 worked like the 88's does. In the winter the 95 blows cold air the minute you turn it on. The 88 sits in the garage all winter so I can't use the ECC in the heat setting :hick:
