Technical => Engine Tech => Topic started by: Wolfskin on September 22, 2009, 02:15:44 PM
Title: What is FE?
Post by: Wolfskin on September 22, 2009, 02:15:44 PM
What are FE parts? How can I identify them, and why do people want them. The reason I ask is that I have a 289/302 4bbl intake off a 68 mustang, that I no longer need, and I'm wondering what I should sell it for. any help would be appreciated. Thanks.
C8ZE-9425-A  7M27
Title: What is FE?
Post by: RoyLPita on September 22, 2009, 02:27:17 PM
FE "Ford Edsel" engines are from '58-'76. The come in the following displacements: 317, 341, 368, 332,352,390,406,410,427, and 428. The intake that you have will not work on these motors.
Title: What is FE?
Post by: 86XR7project on September 22, 2009, 03:54:06 PM
289/302 is part of the same family. FE engines have nothing in common with the 289/302.
You are all good.
Title: What is FE?
Post by: Kitz Kat on September 22, 2009, 06:21:24 PM
Any chance it's a trip?
Title: What is FE?
Post by: TurboCoupe50 on September 22, 2009, 10:25:22 PM
Quote from: RoyLPita;292203
The 317, 341, & 368 ARE NOT part of the FE family...
Actual displacements are 332, 352, 360 & 361(same bore & stroke), 390 & 391(again same B&S), 406, 410(Mercury only), 427 & 428...
The 317, 341 & 368 are part of the Big "Y" block family, NO parts interchange with a FE... The FE were built from '58-'76, the 317, was first used in Lincolns in early 50s the 341 in '55 & 368 in '57... May not have the dates exactly correct but all three defiantly preceded the FE...
Title: What is FE?
Post by: Wolfskin on September 23, 2009, 04:46:15 AM
ok. Thanks everyone. Anyone know what one of these is worth?
Title: What is FE?
Post by: TurboCoupe50 on September 23, 2009, 08:35:35 AM
Would have saved some time IF you'd checked your original post...
http://www.foxtbirdcougarforums.com/showthread.php?t=25538&page=2
Title: What is FE?
Post by: RoyLPita on September 23, 2009, 08:56:15 AM
Quote from: TurboCoupe50;292253
Thanx for the clarification. The source that I got this from was not so truthful.
Title: What is FE?
Post by: Innes on September 23, 2009, 02:48:13 PM
Ford Edsel- I learned something I always wanted to know today. I always new it wasn’t fuel injection and it meant something else on a series of big blocks but never had that patients to look it up.
Title: What is FE?
Post by: 86XR7project on September 23, 2009, 03:29:04 PM
IIRC the truck versions of the FEs were called FT blocks (Ford Truck)
Title: What is FE?
Post by: TurboCoupe50 on September 23, 2009, 06:26:13 PM
Quote from: 86XR7project;292320
That's correct, those had a steel crank and had the rated 361 & 391 displacement... I probably should have mentioned the FT was a off shoot of the FE...
The 361 of '58 was a Edsel engine, wasn't used in any Ford, don't think the Mercs used it that early(hence the FE)... The later 360 was a P/U engine...
BTW the MEL series that came out in '58 stood for Mercury Edsel Lincoln... I believe the smallest was a 383(Mercs & Edsel) with the Lincolns getting a 430.. It was eventually upped to 462 prior to being dropped in '68 for the 460...
For '60 the T-birds had a NASCAR option of the 430 with a three speed tranny... Was the only year a MEL was available in a Ford... '60 was also the first year for a Hi Po FE... The 352 was fitted with a mechanical cam, aluminum intake and header type exhaust manifolds... Rated at 360Hp, not many were produced, it's extremely rare these days... '61 brought 390s from 300Hp to 401Hp Hi Po units with three 2bbl carbs... Also was a 375Hp 4bbl version as well as a 335Hp Police Interceptor, all three had mechanical camshafts...
To throw the fuel to the Ford vs Chevy wars, in Late '61 Chevy built a hand full(175 or so comes to mind) of the 409 "Bubble Top" Belair's... Ford answered with two Hi Po 406s, one with a 4bbl(385Hp) the other a 405Hp three deuce mill... The 406 was avail till mid 63, when the 63 1/3 Galaxie Fastbacks were introduced in Jan '63... Also introduced with the fastbacks, was the famed 427 with a single 4bbl rated at 410Hp, and dual quads at 425Hp... Ford promptly cleaned house at the '63 Daytona 500, taking the first five finishes...
Title: What is FE?
Post by: HAVI on September 23, 2009, 06:38:56 PM
MEL's are da bomb!
Title: What is FE?
Post by: TurboCoupe50 on September 23, 2009, 06:59:39 PM
Quote from: HAVI;292348
MEL's are da bomb!
Yeah stock ones are exactly that if you try to turn em much past 5500 RPM...
