General => General Fox T-Bird/Cougar Discussion => Topic started by: softtouch on September 09, 2009, 09:45:16 AM
Title: The tool everyone should have
Post by: softtouch on September 09, 2009, 09:45:16 AM
Read this mans opinion of the test light.
http://mypage.direct.ca/k/kdomries/testlight.html
Post by: daminc on September 09, 2009, 11:27:07 AM
I don't even own a test light. It's never really slowed me down any.
Post by: Ryan H on September 09, 2009, 01:11:47 PM
Test lights do make electrical diagnosis (in most cases, anyway) very easy once you find where you need to be testing.
Post by: mcb82gt on September 09, 2009, 03:41:32 PM
Ive never used one, dont own one.  Maybe I'll get one.
Post by: daminc on September 09, 2009, 04:08:25 PM
I'm a multimeter man
Post by: Tbird232ci on September 09, 2009, 05:22:00 PM
I'm the tool everyone should have.
Post by: 86XR7project on September 09, 2009, 05:41:22 PM
Quote from: Tbird232ci;290577
You're just one big tool aren't you?
:rollin:
Post by: FLSTCI71 on September 09, 2009, 09:59:04 PM
I love my test light too. I use it quite a bit. It does make electrical stuff a lot quicker to diagnose (usually).
P.S. Jerry, you can't use a test light to fix rust, so not having one wouldn't hold you back at all. lol.
Post by: shameless on September 09, 2009, 10:48:25 PM
Dont own a multi meter anymore, but I've owned at least a dozen test lights in the past, I currently own 3, one in my garage, one at my shop, one in the car at all times. lol you just never know when you'll need one. lol
Post by: Tbird232ci on September 09, 2009, 10:58:44 PM
Quote from: 86XR7project;290583
:rollin:
Came factory equipped ;)
Post by: blu84302 on September 10, 2009, 03:29:04 AM
You can't OHM a newer style fuse with a test light.  Also You can't check voltage with a test light.  That's why I use a multimeter.
Post by: Watchdevil on September 10, 2009, 09:39:05 AM
Multimeter dude here!
Post by: Cad-T-Bird 500 on September 10, 2009, 10:02:08 AM
I use both and for the price of a test light there is no reason not to have both.  Just for testing to see if a wire is hot or not a test light cannot be beat; like hooking up a trailer plug.
TED
Post by: Ryan H on September 10, 2009, 10:05:46 AM
The multi is good for most stuff, but some things require a test light instead.
Post by: TurboCoupe50 on September 10, 2009, 10:43:23 AM
Quote from: Ryan H;290684
AGREED... Unless you're VERY experienced, a meter can get you in trouble... With the high resistance input of a meter, it'll tell you there is voltage available, while a test light will confirm it's just a potential from a poor/corroded connection...
If you're familiar with your test light, it's possible to know the approx voltage from the brightness of the bulb...
Me, I mostly use meters(have a dozen or more), but I keep the test light handy...
Quote from: Cad-T-Bird 500;290681
TED
Exactly the situation I was referring to... Anybody that's worked on trailer lights knows there are always poor connections, that will often show a voltage using a meter but still will not burn the lamps...
Post by: Loaded87IROC on September 10, 2009, 10:51:37 AM
I have and use them both.  Test light is good to have for pulling EEC codes.
Post by: TurboCoupe50 on September 10, 2009, 11:13:21 AM
Quote from: Loaded87IROC;290700
The Hell with that, I use one of these... Mine is older(had it for probably 15 years), says from 1981 to present, instead of 1981 to 1995 like the later models...
http://www.equus.com/product_info.php?product_id=3145&category_id=1
Should be able to get one cheaper from ebay...
Post by: 5.0 tbird on September 10, 2009, 11:42:35 AM
Multi-meter ftw. I have a couple digitals and an buttstuffog.
Post by: Masejoer on September 10, 2009, 01:24:29 PM
I bought a test light years after using only multimeters. I used it once and it wasn't all that useful until it got dark out. Multimeters with a light built in are very helpful in all areas (these ones usually have more capabilities than cheapo meters also). $50 can get you all that along with temperature, sound level, etc readings. Nice toy to play with.
Post by: CoogarXR on September 10, 2009, 09:27:33 PM
I am a multimeter man myself too. I probably have 10 or 15 of em. I probably have 10 test lights too though. I mostly use test lights for troubleshooting fuses, lighting circuits and installing stereos (finding the constant hot/switched hot).
Seek mentioned backlit multimeters, Harbor freight sells a backlit multimeter for 3.99 when it's on sale. It's usually like 7.99. I don't own one, but that's about the cheapest backlit meter you'll find.
Post by: Masejoer on September 13, 2009, 06:13:51 PM
I guess I more of meant a multimeter with a test light built in but a backlight can be useful also ;)
