Technical => Engine Tech => Topic started by: Dansbirds on September 03, 2009, 07:29:13 PM
Title: Need help from the turbo guru's
Post by: Dansbirds on September 03, 2009, 07:29:13 PM
What size and where do I get the fitting that goes in the turbo for the oil feed line to thread onto?  Is it a metric thread? Should that be installed with some type of sealant? Thanks in advance for any and all replies
Post by: Chuck W on September 03, 2009, 07:47:34 PM
You using a stock feed line? (the hard one with the inverted flare fitting)
It's a T3 turbo, correct?
If that's the case, what you do is email me your address and I will ship you one.
cwarren@indy.net (email please...no PM)
Post by: 88turbo on September 03, 2009, 07:49:09 PM
1/8th inch NPT I might have one that I could mail to you if you'd like.
