Technical => Engine Tech => Topic started by: 86caprirs on August 27, 2009, 09:24:53 PM
Title: 5.0L stumble.
Post by: 86caprirs on August 27, 2009, 09:24:53 PM
I got a stumble off of idle. Kinda reminds me of an accelerator pump on a carb gone bad. You gun it in neutral and it stumbles then catches.I also feel it when I am driving on freeway and gun to pass traffic. Any ideas?
Post by: mcb82gt on August 28, 2009, 08:27:25 AM
Any fault codes? Start there.
When was the last full ignition tune up? Fuel filter changed?
Post by: thunderjet302 on August 28, 2009, 12:56:10 PM
Quote from: mcb82gt;288654
any fault codes? Start there.
+1
Post by: 86caprirs on August 30, 2009, 11:42:02 AM
I changed the fuel filter because it looked really rusty. I was driving it the other nite and I desided to floor it to clean it out. The tach was jumping up and down and the car was missing really bad. Also the temp gause went way up. To just pass the N on normal. Took a bit for the temp to come down. I smell coolant also. Hmmm. I need to investigate.
Post by: jcassity on August 30, 2009, 09:01:48 PM
codes is a good start,,
if no codes, sound exactly like the results you would get with injector screens being too dirty.
Post by: 86caprirs on August 30, 2009, 10:39:45 PM
Well I am starting to get the miss at idle hot so tomorrow I will check for codes.
