Technical => Engine Tech => Topic started by: Loaded87IROC on August 27, 2009, 03:06:33 PM
Title: EGR question
Post by: Loaded87IROC on August 27, 2009, 03:06:33 PM
I took off my EGR valve to test/clean it and had a question.  Shouldnt I be able to move the valve (I guess thats what you call it) that sticks out of the second hole pictured on the base? (not counting bolt holes)
(http://img.photobucket.com/albums/v648/Loaded87IROC/IMG_1499.jpg)
Title: EGR question
Post by: Kitz Kat on August 27, 2009, 05:08:22 PM
Put vacume to it and see if it will hold.
Title: EGR question
Post by: Loaded87IROC on August 27, 2009, 05:22:10 PM
Thanks for the response!
Well I dont have a vacuum pump, but by attaching a vacuum hose to it and sucking nothing happens.  Its just like sucking through a straw.  It wont let me blow through it however.  I sprayed some wd40 on the valve and let it sit for a few minutes and then messed with it some more and it freed it up, but still nothing when i suck on it and if press it in and cover the vacuum port, the valve still just pops back out.
Title: EGR question
Post by: Kitz Kat on August 27, 2009, 06:38:06 PM
Take a main vac line from your car, hook it to that see what it does. but really even with your lips you should be able to suck it open. Sounds like it's shot.
Title: EGR question
Post by: Loaded87IROC on August 27, 2009, 06:52:16 PM
I tried using a main vacuum line too and it didnt do anything different.  Looks like i'll have to spend the 85 bucks on a new one.
Title: EGR question
Post by: Kitz Kat on August 27, 2009, 07:05:49 PM
Don't do that, there all over the yards. I got 2 in my trunk, I really don't know why.
Give me an address, I'll send you one. It won't hurt it to run it with the vac line plugged till you can replace it.
Title: EGR question
Post by: Loaded87IROC on August 27, 2009, 07:15:30 PM
Thanks!  I will cap it off even though I don't think I will be driving it.  I have only put about 200 miles on it since i bought it 4 months ago.
PM sent
Title: EGR question
Post by: softtouch on August 27, 2009, 07:29:06 PM
The EGR position sensor has to be on the top for it to hold a vacuum.
Title: EGR question
Post by: Loaded87IROC on August 27, 2009, 07:34:07 PM
I had the sensor in place for the series of "tests" I did.
