Technical => Misc Tech => Topic started by: t3skidoo on August 16, 2009, 08:07:18 PM
Title: changing gas tanks
Post by: t3skidoo on August 16, 2009, 08:07:18 PM
I'd like a little more fuel capacity.  I can get the tank modified but will probably be a little pricey.
Will the 87-88 gas tank fit in a 83-86 TC?
Post by: TurboCoupe50 on August 17, 2009, 09:59:34 AM
I'd think it'd work without issue, but you may need the filler neck and defiantly the plastic tank guard and straps...
Post by: t3skidoo on August 17, 2009, 11:10:04 AM
Ah good points, thanks.
Post by: cougarman on August 17, 2009, 11:19:13 AM
Might want to double check, if the sending unit and fuel pump hookups are the same. I'm trying to remember, I once put an '86 gas tank in an '84, and had trouble with the sending unit. I think the '84 had a seperate unit, and the '86 had it all in one, or yice-versa, been awhile..lol.
