Technical => Engine Tech => Topic started by: Greg Price on August 14, 2009, 01:39:59 AM
Title: oil pressure sensor
Post by: Greg Price on August 14, 2009, 01:39:59 AM
This is not for a fox body . But I figured you guys could help me out.
I unplugged the oil pressure sensor on my 1990 olds cutlass ciera to change the gasket on the oil filter adapter. the sensor is located on the adapter piece . i plugged it back in and now it does not work properly. it points straight up . when you start engine it just moves a tiny bit to the right. car runs fine. Any help .Thanks :D
Post by: vinnietbird on August 14, 2009, 08:01:08 AM
My Sport just had that problem 2 weeks ago.I swapped the sensor out with a brand new one and my problem was solved.
Post by: mac_55 on November 18, 2009, 04:05:03 PM
i have the same problem with my 87 cougar the oil light is always on and when i unplug the wire to the oil pressure gauge the light goes out. I'm going to hook up a real pressure gauge tomorrow to see if there is pressure or just a faulty sensor.
would there be any other reason why the light is always on or has someone else also had this problem
87 cougar, 89 gt 5.0 H.O swap, long tubed headers, 8.8 posi swap, Mass air
Also i just looked up the oil pressure switch and the mustang had the gauge were the cougar has the light, so would a oil pressure switch with gauge not work for a cougar switch with light ??
Post by: mac_55 on November 19, 2009, 02:11:30 PM
$7 and a quick trip to the parts store and problem solved
