Technical => Engine Swapping => Topic started by: Warbird9 on April 09, 2005, 01:31:13 AM
Title: 351 Question
Post by: Warbird9 on April 09, 2005, 01:31:13 AM
For those of you with 351's using sepentine belt drive, are the brackets for the accessories 351 specific, or interchangeable between 351 and 302? Just working on my swap list, and figured this was a good time to get this part outta the way.
Thanks folks! :D
Title: Re: 351 Question
Post by: TurboCoupe50 on April 09, 2005, 07:39:09 AM
The alt/smog bracket is same, p/s & a/c is different. I believe you'll need the Mustang type p/s pump mount(on the pump) as the Bird/Coug mount won't fit the 351 bracket.
Post by: SirChirpAlot on April 09, 2005, 08:40:44 PM
I only run crank waterpump and alt all on one sepentine belt.
I used mustang underdrive pullys and made my own alt bracket
Post by: Warbird9 on April 13, 2005, 06:25:06 PM
Hi guys, sorry about the delayed reply, but thanks for the answers. I'll need to keep my smog pump, but the a/c already went buh-bye. I'll be looking into a Procharger unit, but need to check with them about mounting solutions.
Their website doesn't mention 351's, but the pic they show for the 5.0 has the a/c in place, and the supercharger beside it. Easiest mounting for routing their intercooler I guess. Need to find out if they offer mounting brackets for non a/c apps. with a 351.
Thanks again guys! :D
