has anyone tried to use the 70's style mounts in an 87-88 bird? just curious as to why they wouldnt work.
Edit: forgot to add that this is for a 5.0
What are the "70's style mounts"?
The K-member is the most likely reason...
70's style mounts like what I have in my cougar. the bolt through frame type mounts, the 87-88 use the same type of mounting. I will try these when we drop the engine in the new TC and let everyone know either way.
What's the application?
I imgaine they might be "short" compared to the 86+ style.
I looked some up. ('77 Tbird w/ 302).
They'll probably hit the K-member before you can get the bolt through them.
thats what I was affraid of.... we arent needing them right now but how much are you asking for your mounts chuck?
Well, I'm not saying the other ones WON'T work, but from the pics I looked at they looked to be "short". The Fox mounts are kind of tall.
My mounts run $175, to your door.
