Well at some point I have misplaced the clips that hold the metal trim pieces up that go over the doors.
I get them all painted up and now I can't find the clips :hick:
I can't believe I can't any from the 2 other interiors I have taken apart :punchballs:
There are 2 clips per side IIRC.
Chuck
cwarren@indy.net
HA!!:evilgrin
City please,, as mapquest shows no "indy":D
jk,,
I'll see bout the clips,, i am pretty sure i know which ones you are talking about. The interior dew wipe clips? if im wrong, then im not sure what part of the door you mean.
Scott,
Sit in the driver seat, look to your left, look up. That piece of metal trim (between the A and B pilars) above the door. It's held to the body with two largish clips. I need 4 of those clips.
no way in hell i have those,, sorry. misunderstanding.
Those parts are under the trim holding the headliner up.
I know who might have them,,,,Dr D on the old bird he is parting. Maybe those on his bird might be more year friendly with your model.
i'm sure i got them, I'm just a little confused what your talking about. i sat in the car, looked left, then up and I dont see clips. althought I dont know the difference between a and b pillars either.
The A pilar is the front pilar (windshield), the B pilar is the rear of the front door, the C pilar is the one at the rear (rear window).
You won't see the clips because they are behind that metal piece of interior trim, holding it up. You have to remove the one phillips-head screw at the rear of the piece, and then basically yank on that piece of trim to remove it.
I've checked 3 places now, and it appears all 3 sets of clips I had have gone AWOL.
Look at the pic here.
(http://www.turbochuck.com/images/Tbird/Seats/Interior.jpg)
See the missing piece above the pass door?
The clips are what holds it up, and that is what I need.
Okay, I'll go out there tomorow and remove the piece. That piece hasn't been removed so I'm sure I have them.
Still looking.
STILL looking.
and still looking...
Chuck,I'm hitting the yard Monday early morning (if all goes as planned).I can probably grab a few.I'll let you know.If I can,I'll drop them in a padded envelope for you.I have to send Daminc a package as well.
Vin, just let me know if you find them. They may be 83-85 only. I dunno. I just need 4. Even two would get me by.
Thanks
I'm very certain that on '87-88's the trim is held on simply by self tapping screws which go into the sheetmetal. At least, the 4 '88s I've had were that way...
