Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: V8Demon on June 17, 2009, 02:19:12 PM
Title: Fuel lines
Post by: V8Demon on June 17, 2009, 02:19:12 PM
Stock preformed rubber/vinyl fuel lines -- 5.0 EFI catbird/Mustang.
Hit me up  ;)
Title: Fuel lines
Post by: 32VFoxBird on June 17, 2009, 04:58:48 PM
the ones that go from the frame rail to the fuel rail, or the ones the rear with the filter connections?
Title: Fuel lines
Post by: V8Demon on June 17, 2009, 05:06:56 PM
Not the metal ones.... The loooooong ones with the filter connection.
Title: Fuel lines
Post by: irv on June 18, 2009, 04:16:52 PM
some where there was a posting for a kit to make
them w/fittings. [or was it on foureyedpride.]
doesnt the mustang position the fuel filter nearer the
tank above the rear end? just random dribbling. it
might be easier to cut your own.
Title: Fuel lines
Post by: V8Demon on June 18, 2009, 04:42:21 PM
I have my own now.  The return line I have is the stocker and the feed line is rubber.  Works fine enough, but could be an issue at the track....Looking for something they won't bust my chops over without going all out, although they hardly ever even look...
Title: Fuel lines
Post by: irv on June 18, 2009, 05:13:14 PM
mechanic friend down the street uses plastic high pressure
line and fittings. they can make about anything. that might
be the way to go. would look oem. you can go w/ bigger lines
i would assume.
Title: Fuel lines
Post by: Haystack on June 18, 2009, 08:43:28 PM
I have the one that goes from the filter to the fuel rail. I acidentally cut the other one trying to pull them off for ford truck freek.
Title: Fuel lines
Post by: V8Demon on June 19, 2009, 08:47:06 AM
Quote from: Haystack;278563
How much you want?  PM me.
Title: Fuel lines
Post by: Haystack on June 19, 2009, 10:08:41 PM
PM sent.
