Technical => Suspension/Steering => Topic started by: 83thunderbird on June 13, 2009, 11:47:17 AM
Title: 245/40/17 will not fit the front
Post by: 83thunderbird on June 13, 2009, 11:47:17 AM
anyone got a 2" drop on their thunderbird and swing a 17*9 rim...just try 17*9 with a 245/40 and it washiznitting the strut and the car was on jack stands...would it clear if the car was on the ground....its only the front that have that problem...would a 235/45/17 fit or a 235/40/17...
Post by: 32VFoxBird on June 13, 2009, 06:03:49 PM
depends on the offset
Post by: vinnietbird on June 13, 2009, 06:37:49 PM
They fit mine.....with a 2 inch drop.put a spacer on the rotor and then install the wheel.
Post by: t3skidoo on June 13, 2009, 11:22:13 PM
Quote from: vinnietbird;277496
+1
9" wheels will fit, but odds are you're going to have to play with the offset.
Post by: bduly on July 28, 2009, 02:48:10 PM
Right now I'm running 245-45s on my fronts with 17x9 cobra knock-offs (don't know the backspacing), and suspension techniques lowering springs (2") without any tire rubbing. I do have the shorter lower control arms ('86 tbird) which bring the wheels inboard but I'm not sure they're necessary for the tire clearance...I did it for the stance.
Post by: 50tbrd88 on July 28, 2009, 06:49:32 PM
I run steeda springs (not sure how much they lowered...at least 2") with 17x9 generic cobra r's.  Not sure what my offset is either.  I have stock lower control arms and no rubbing.
Post by: vinnietbird on August 02, 2009, 05:46:23 PM
I'm running 255 40 17's up front.No issues.
Post by: 88BlueBird on August 11, 2009, 04:29:16 PM
I've got 245 50 16's, but I have to run 1/4" spacers up front with the stock suspension for tire clearance to the strut.
