Technical => Engine Tech => Topic started by: quick50stng on June 03, 2009, 07:08:54 AM
Title: Anyone know nut size for studs to exhaust for mustang headers?
Post by: quick50stng on June 03, 2009, 07:08:54 AM
Anyone know nut size for studs to exhaust for mustang headers? I've tried 7/16 coarse thread and doesn't fit. Grabs a few threads and stops
Post by: vinnietbird on June 03, 2009, 08:43:52 AM
I just used new header bolts.Nice and clean that way.
Post by: Kitz Kat on June 03, 2009, 09:09:18 AM
I checked the set here at my shop and its 7/16x14, and thats what you tried.
Post by: quick50stng on June 03, 2009, 11:40:47 AM
Yes, 7/16 -14 coarse and doesn't want to go up on. I've bead blasted them and everything so no dirt or grime in the threads either.
Well
Post by: V8Demon on June 03, 2009, 01:04:00 PM
Sounds like you need to tap the holes...
Post by: 20thanniver-ls on June 03, 2009, 02:35:41 PM
I had  the exact same problem with mine, they would start, and then they would lock up.
Post by: Kitz Kat on June 03, 2009, 03:21:10 PM
Run a die or a chaser over them.
Post by: thunderjet302 on June 03, 2009, 06:58:55 PM
Long bolts and nuts work too ;)
Post by: EricCoolCats on June 03, 2009, 07:04:43 PM
They're shallow threads in the factory nuts...that's how most of the Ford exhaust bolts I've ever run across have been.
Post by: mjbtbrd on June 03, 2009, 07:22:17 PM
IIRC  it is 7/16X20 going into the header  and the other end where the H pipe retaining nut threads on is 7/16 x 14.  I got some at ACE Hardware, but any good hardware with a fastener isle will have an exhaust stud drawer.
Post by: quick50stng on June 03, 2009, 10:45:48 PM
7/16-14 works fine now just needed to add anti seize to the studs and a bit of persuasion at the start and they spun right on with out a problem. X pipe is on:D
