Technical => Misc Tech => Topic started by: BlackCardinal on May 11, 2009, 01:11:53 PM
Title: My A/C is giving me cold feet!
Post by: BlackCardinal on May 11, 2009, 01:11:53 PM
Okay, so I’m driving along, minding my own business (Don't I always?). It’s pretty hot outside, so the A/C is blasting away, blows pretty cold. I go for a quick right turn and BLAM!...my right foot freezes! Actually, it’s soaking wet—from ice water! I conclude that it’s obviously condensation off of the evaporator; apparently has no where to drain. My question is: is the condensation normal? If so, IS there a drain for it, and perchance could it be clogged?
Post by: softtouch on May 11, 2009, 02:37:08 PM
Yes yes and yes.
Post by: BlackCardinal on May 11, 2009, 07:14:17 PM
Lol!...Succinct and to the point! Love it!....Well, thanks, that answers those questions!...now I guess I gotta get under the dash and find the drain tube....any pointers before I get to rippin stuff out?
Post by: TurboCoupe50 on May 11, 2009, 07:19:42 PM
Drain tube exits into the engine compartment... It's down low, about where the fire wall curves under, just about directly below the AC lines...
Post by: MasterBlaster on May 12, 2009, 02:36:48 AM
Here it is. Big rubber plug with a short snout in the middle. You can probably reach it from under the hood, squeeze and wiggle it, or shove a pencil up the snout to dislodge any  plugging it up.
Post by: BlackCardinal on May 12, 2009, 11:03:47 AM
Cool! Thank you all for your comments! It's been a great help!
Post by: BlackCardinal on May 18, 2009, 04:25:56 PM
Okay, I finally got under the hood this weekend. I found the drain tube and snaked a piece of antenna inside...I'd say I pushed it in about an inch before I got a steady stream of water coming out! I'd say about 1/3 of water or so was under the dash!...things are much better now! Thanks again for the help guys!
