General => Lounge => Topic started by: 83-88T-Bird Guy on April 30, 2009, 03:11:34 PM
Title: Got my widened 4 lug Center Line Auto-Drags back
Post by: 83-88T-Bird Guy on April 30, 2009, 03:11:34 PM
Ever since the mid-80's when the Center Line auto drags were popular, I have always wanted a set. (polished of course)
My buddies had them on their Pontiacs and I thought they looked so cool. I was jealous.
Well, I sent my 8.5s off to http://www.weldcraftwheels.com and had them widened 1.5 inches. Now the backspacing measures 6.25 inches. They should fit perfect in the TC fenderwell. The welding work looks superb!
Now I can mount the old set of BFG 325-50-15's (off my wife's T-Bird) on my 460 Turbo Coupe and finally get the look I have wanted for years with my favorite size rear tires. :D
UPDATE: Newer pics on page 3 >
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/widenedcenterlines2.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/widenedcenterlines1.jpg)
Post by: daddybair7 on April 30, 2009, 03:23:23 PM
They look good very nice
Post by: 50tbrd88 on April 30, 2009, 03:37:59 PM
Nice!
Post by: massCougarxr7 on April 30, 2009, 03:55:53 PM
BAD A$$!!!!!! Dont forget to show us pics with them ON the car!!!!, wonder why they didnt smooth out the welds,...... might end up with some hefty wheel weights!!!
Post by: 86XR7project on April 30, 2009, 04:43:04 PM
Quote from: massCougarxr7;269870
Because you won't be able to seem em when the tires are on and I doubt they'll need that large of a weight looks like the guy did a darn nice job.
Post by: Chooglin on April 30, 2009, 04:47:34 PM
very nice,I like those
Post by: Tbird232ci on April 30, 2009, 06:43:02 PM
Grinding down the welds can actually weaken the weld.
Post by: 5.0 tbird on April 30, 2009, 07:45:00 PM
Yeah, you don't wanna risk such a thing on wheels.
They look good make sure to post some pics when they're mounted.
Post by: V8Demon on April 30, 2009, 08:33:53 PM
A tire will throw off the balance on that wheel more than those welds will...
Post by: Bob on April 30, 2009, 09:32:45 PM
Looks great, when they going on the car?
Post by: shame302 on April 30, 2009, 10:22:59 PM
Kuh Ching
Post by: 83-88T-Bird Guy on May 01, 2009, 03:45:12 PM
Quote from: Bob;269950
Soon. I got the tires mounted and one wheel polished. I am anxious to see how they fit.
Polishing around those rivets is a bitch....but well worth it !:D
Post by: shame302 on May 01, 2009, 05:19:29 PM
you should be able to just pop the rivets out from the back, polish the wheel and them separately and tap them back in.
Post by: 86T-bird on May 01, 2009, 07:51:54 PM
Polishing with one of the Power Balls will do the trick.  I have a set of front runners I used one on, 20 minutes and they came out great!
I picked up a set of widened wheels from Weld Craft on Wednesday!  Second set I have had done.  Added 1 1/2" to a 7 1/2"X16" Filipaldi wheel.  Ended up with a 6.5" back space.  I'm techically challenged on getting pics posted...  But the welds look the same.
Post by: massCougarxr7 on May 01, 2009, 09:25:01 PM
Quote from: Tbird232ci;269917
LOL i know, how to mig, stick, and tig weld,.... so i know that grinding them weakens them....... he did run nice even beads tho,... i just never knew that rims could be welded wider,,... ive never seen it before!!!
Post by: 83-88T-Bird Guy on May 08, 2009, 07:37:46 AM
I got one installed last night.
In retrospect, I should have had 2 inches added to those 8.5's instead of 1.5 inches. That would have moved the tire in 1/4 inch more.
Overall, I am pleased because I can also use Fox Mustang axles with small spacers to place the wheel in more if I so choose.:D
I am also looking for 2 small center Line caps like the pics below show. These are slide thru from the rear type and are steel w/chrome plating. Fits 2 3/4 inch bore.
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/elliot6wclines6.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/elliot10wclines10.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/elliot2wclines2.jpg)
(http://i273.photobucket.com/albums/jj226/carmagguy/clinecaps3.jpg)
(http://i273.photobucket.com/albums/jj226/carmagguy/clinecaps5.jpg)
(http://i273.photobucket.com/albums/jj226/carmagguy/clinecaps4.jpg)
Post by: massCougarxr7 on May 08, 2009, 09:14:17 AM
Looks sweet!!!!
Post by: 86T-bird on May 08, 2009, 09:46:52 AM
Those are monster meats!  It's great to see how big a tire these cars can swallow.  Nice choice on the Auto Drags.
Post by: 83-88T-Bird Guy on May 08, 2009, 10:30:36 AM
Quote from: 86T-bird;271214
Thanks.
At least we Fox Cat/Bird owners have one thing over the Stang guys, and that is 325-50-15's fit well in the factory wheelwell. :D
Post by: DVP on May 08, 2009, 10:35:42 AM
Quote from: 83-88T-Bird Guy;271222
Thanks.
I need to fill out my rear wells.
Look good on there.
Front tire on backwards?
Post by: 83-88T-Bird Guy on May 08, 2009, 12:30:58 PM
Quote from: DVP;271223
Look good on there.
Thanks.
No the front wheel is a 16 x 8 with 5" b.s. and a 225 tire. Doesn't fit the car well. I need those in a 16 x 7 size.
I can't wait until I get the caps and intall the skinnies to match the rears.
Post by: turbo83coupe on May 08, 2009, 12:39:10 PM
WOW!!  That looks soo aggressive!!
Post by: 5.8fastcat on May 10, 2009, 11:34:36 PM
Looking Great.
  I guess you heard about US60 opening later in May?????
Post by: badbird84 on May 11, 2009, 01:05:24 AM
Good looking widening job and never grind those welds. The welds will not throw the balance off. I used to widen rims on the side.
Roger
Post by: 83-88T-Bird Guy on May 11, 2009, 07:16:03 AM
Quote from: 5.8fastcat;271608
Looking Great.
Greg:
I knew they had the electric turned on but have not heard any info from the "official" guy in the know.
Post by: stormtroopin' on May 11, 2009, 11:59:04 PM
The fender looks like it was designed for that wheel and tire combo.  Looks awesome!!!
Post by: 83-88T-Bird Guy on June 26, 2009, 08:31:45 AM
Update:
I put a  skinny on the front and got some shots.  Hopefully soon the 512 BB will be ready and then I will order some new 325-50s for the rear and have fun !
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/CenterLskinnies02.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/CenterLskinnies03.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/CenterLskinnies05.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/CenterLskinnies01.jpg)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/CenterLskinnies04.jpg)
Post by: vinnietbird on June 26, 2009, 06:15:50 PM
Niiiiiice !!!! That's a LOT of tire back there.I'm impressed.....really impressed.Looks great.
Post by: 50tbrd88 on June 26, 2009, 08:18:52 PM
Golly...thats Bad Azz.  Talk about some serious meats.
Post by: Beau on June 27, 2009, 02:36:40 AM
Looks like it was always meant to be. :D
You said something about a Mustang rear...from a Fox, correct?
Jus' checkin'...;)
Post by: 1986Élan on June 27, 2009, 10:05:04 AM
i feel like havin my back wheels widened as well i think theyre only 6 or 7 inches wide
i was wondering around what price is reasonable to pay for such a job
and is there anything to consider like back space or anything like that or i can just add    1 -2 inches and put them back on with another set of tires
 btw they look terrific!!!!
Post by: 83-88T-Bird Guy on June 27, 2009, 11:00:37 AM
Quote from: FordTruckFreeek;279926
Jus' checkin'...;)
That car has the original TC rear, but converted to drums. It has the T-Bird axles. If I wanted to move it in another 1/4 to 3/8 inch I would use Fox Stang axles and spacers to put the tire where I wanted it. However, after driving it I think where the tire fits now is perfect. :D
Post by: 83-88T-Bird Guy on June 27, 2009, 11:10:46 AM
Quote from: 1986Élan;279946
I paid $ 175.00 per wheel to have them widened. It is the same price all the way up to 3 inches widened.
Those Center Lines have 6.5 inch backspacing. I should have had them widened 2 inches instead of 1 1/2 in. and it would have moved the tire in another 1/4 inch. :punchballs:...oh well, didn't know.
If you widen a stock 7 in. wheel, and put a fat tire on it, you will probably need to add spacers between the wheel and axle to correctly locate the tire in the wheelwell. That will require upgrading to 3 inch wheel studs.
Post by: 1986Élan on June 27, 2009, 08:45:51 PM
thanks alot for the info!!!!
Post by: CatCarMan2012 on June 27, 2009, 09:35:38 PM
Do you have exhaust dumps?  My pipes are already pretty close to the 235s i have on the car.
Post by: 83-88T-Bird Guy on June 28, 2009, 12:44:12 PM
Quote from: danzajax;279997
Yes, they exit before the axle.
There is no way over the axle pipes will work on either of our 460 Birds.
