would an 86 turbo coupe have a push on or screw on rotor?
thanks
dan
Looks like a push-on to me...
http://info.rockauto.com/Airtex/Detail.html?4R1089.jpg
(http://info.rockauto.com/Airtex/4R1089.jpg)
That is sorta a divided year you could have either. If it is an early production then it should have the screw on type if it was late production is should have the push on. That is assuming that the Dizzy has never been changed. Then it could be either way. But the safest way would be to get up remove two screws and make sure.
