Technical => Engine Tech => Topic started by: xr748072 on March 20, 2009, 09:42:29 PM
Title: plastic fuel lines
Post by: xr748072 on March 20, 2009, 09:42:29 PM
snaped a plastic fuel line close to engine is there any kits u can buy to splice the line where it broke
Post by: Grumbles on March 20, 2009, 10:07:43 PM
Yeah buy a hose and connect the busted pieces :D
Post by: Cougar5.0 on March 21, 2009, 11:44:34 AM
Not sure how you can splice it, but OEM plastic line is available here. (http://"http://www.ronmorrisperformance.com/miva/merchant.mvc?Screen=CTGY&Store_Code=rmp&Category_Code=Fuel_Fittings_and_Fuel_Line")
Title: thnx a million
Post by: xr748072 on March 21, 2009, 12:18:17 PM
Thats what i was looking for .Just dont trust a rubber hose ans some clamps on a  preasure hose
Post by: cougarman on March 21, 2009, 12:46:25 PM
Barb fittings like these work very well for splicing the plastic fuel lines. You just heat up the fitting, and press the tubing on, let cool. :burnout: Fairly cheap at Homedepot, or Lowes.
Post by: flylear45 on March 22, 2009, 07:42:28 AM
What courgarman said. You can also find them at the parts stores in the HELP section.
Post by: xr748072 on March 22, 2009, 08:13:50 PM
sounds real good thnx for the info
Post by: blackcougar71 on March 24, 2009, 01:42:39 PM
parts store have a fuel line repair and you use a barb fitting to connect the two line together.
Title: fuel lines
Post by: masonsdad on April 02, 2009, 01:22:27 PM
on the 88 TCs do those fuel lines have a plastic inner tube over the rubber line???  seems like they do because I can't the bottom duckbill fittings off!!!
