I call upon the great wisdom of the board...... please enlighten me.
I found a fella that has a pair of Channel Weather Strips for the windows. He has an 87 tbird.... I have an 85. Is this a good donor for me?
Thanks in advance. I am ever thankful for your knowledge.
No. They're differenter.
Are they removed the same way as the '88? If so,I can get some next week,maybe Saturday.
They come out the same way, Vinnie.
The biggest difference is in the corners. On the 1987-88 doors the glass is more rounded in the top corner; the older cars don't have as much as a radius. As a result, the channel run is seamed differently in the corners. I am not positive but I do remember the widths being different as well. Everything changed with the flush glass design in 1987, unfortunately.
Hello I read your question.And I have found online a company that
maybe able to help you. their web site is. http://www.restorationspecialties.com I hope this helps you.
a swing and a miss on the window channel weatherstripping.... and the sun roof weatherstripping. But they do have the inner and outter rubber for the doors. 4 pieces (two each side) $200.
FYI
