Got a tailpipe installed. After the motor and trans go in, I'll get the everything else done.
The low point is about 4" off the ground, not so good. It really is tucked up, pretty good.
There's a temporary pipe connecting the old exhaust to the new. It's d so I can drop the IRS without messing with the whole exhaust. At least that was the idea. He welded a mount to cradle so that's going to have to be fixed somehow.
http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=18428&stc=1&d=1233537523
http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=18430&stc=1&d=1233537523
Out the side....
not if you want it legal......
Looks great man!
not everyone lives where you do so some can get away with side pipes, others can afford the ticket.
all i know is here, and mass car will not pass inspection unless it comes out the back
They dont write tickets for it, they revoke registation
I haven't been able to get a straight answer on a side exit in front of the rear wheel. There are a few areas of the law open to interpretation. An oval pipe on the passenger side in front of the rear tire was my first plan.
According to the inspector, it's got to be after the axle and out the side or back. He's probably an idiot, but he's the one punching the ticket, so he calls the shots.
they dont want you idleing and filling the car with fumes and dieing
its been a long time since stock pipes came out the side. I think the cuda was the last i recall doing this in stock form. Pipes were exposed down the sides with a heat shroud over the pipe. Some do it and get away with it but If i were to do sides, there would be a fitting under the front seats so i could install the "over the axle" out the tail end pipes just for inspections.
V8demon posted a pic of a really sweet side pipe exit recently.
Fuuny how many F150s had it Stock. Sure they are farther back not on the Lightings
trucks are different
exhaust HAS to exit after the passenger compartment (after cab) and its legal
Thats up here of course
This is the newest car I've seen with side exhaust:
http://tinyurl.com/ctbct7
That is truly awesome.................
just messed my keyboard:D
