hi guys,im new to the board and couldnt find anything under search
i have an 84 bird 5.0 with the speedo only cluster,are there any other clusters with tach,o.p. water temp and the like that will work in my old bird?
or will a cluster from a 84 cougar turbo work in it ?
thanks
mike
well they make the 5.0 cluster thats like the turbo coupe one without the boost gauge. Or the full digital one.
http://www.coolcats.net/tech/general is a link to where you can click to see the few different clusters availible.
That only applies to 85-88 models. The 83-84 is different. An 84 turbo cluster would work, but the tach would be off. I dunno if the older 4-cyl tachs can be modified to work with the V8
I saw a full digi cluster on Ebay yesterday for that car.
yea i wud rather have the old fashion buttstuffog gauges
mike
joker77_2005,
Check in the body/appearance/interior forum, there are lots of examples there of people doing their own setup.
There was an 83/84 on evilbay that had gauges all the way across the dash. A little much for me, but maybe he was a control freak. Or worked at Autometer.
Just think of your dash as a blank canvas and cut loose. Then come back with plenty of pics.
onmustang 83 to 88 tach have a switch on back to change it from4/6/8cyl. maybe the turbo bird tach the same?
if you mean the digi cluster for 83/84 tbird, thats prolly mine you saw on ebay lol
I dunno about the '83-'84, probably not since the TC is the only one to get a tach... The '85-'88s defiantly do not have a switch... The '87-'88 tach is fairly easily modified for 6 or 8 oper, however the '85-'86 is not..
i think i was saying the mustang has one but i could be not reading what i wrote.
